What I mean by failing is the joists are built using metal plates stamped into the wood framing. My take is with the endless heat and cooling cycles overs the years, many of the plates have separated in part from the wood framing. Easy to fix, a c-clamp will press the plates back into place. However I plan to reinforce the exposed trusses (8) with a pair of 1x4 on each side and fasten with deck screws-basically heavy duty drywall screws that are rust resistant, additionally the V sections of the trusses will recieve a vertical 1x2 posts. This is a band aid repair, what really needs to happen is perhaps hire a engineer and construction crew and replace the low sloping roof 2/12, with a real 4/12 or so truss system with out destroying the inside ceilings drywall . A tall order to be sure.
'Real' meaning using actual construction material instead of the toothpicks they used back in the day when this pos building was constructed.
If the time of year were late spring, instead beginning of fall, I might move forward on this little adventure. For now I need to get the roof ready for the coming rainy season.
The house will be the last of a PV project, for now the shop, that uses real lumber will see the addition of 27 panels before the sees any, so a least 1 to 2 years off.
I think I'm out of luck in having any legal recourse, too many years have passed, and in reality, if you want something done right you have to do it yourse
As I thought about what to do today, I plan to take advantage of the easy access to the attic area and beef up the R values in the ceiling, and run a few new power lines for the new lighting installed to a common light switch j box.
Funny how a simple repair snowballs into a bunch of side projects...
