Hello,
I have installed 100W solar panel on the roof.
The OC voltage is 15V, SC current is 6A (the max it 8A).
My batteries is small capacity (6AH), because I want to use it with sun only.
The problem is: When I connect a laptop (5A) to the system (solar controller + inverter) the batteries gives 3A and the panel 2A. So after short time the batteries discharged and the controller disconnect the circuit.
Why the panel doesn't gives it's full ability?
What should I do to use the sollar power directly (the battery only for backup for shading moments)?
Thanks for any help.
