Hi all,
Thanks for all the replies I got about my other topic on this forum, mounting the inverter in garage. I didn't expect such a good technical explanation on the topic and suggestions to avoid the problems.
Well, I do have a related question - I had received a quote from another Sunpower dealer who has the Aurora Power-One inverter in its proposal (in reality, it will be the Sunpower-branded version). As I have realized the advantage of using the Power-One inverter over the SMA inverters, I am considering their proposal once again. They seem to be more conservative in their shading analysis, compared to the other dealer. So, they proposed PV solar system of size 4905 watts - 15 Sunpower 327W panels (SPR-327NE-WHT-D) with a Power-One PVI-4.2-OUTD-US-240/Sunpower-branded SPR-4200p-TL-1 inverter. All the 15 panels are on the roof facing in the south-west direction. They are going to put 8 panels on 1st MPPT and 7 panels on the 2nd MPPT.
The online Power-One configuration tool Power-One configuration tool shows the "Inverter utilization ratio" of 102.2% for this setup. The dealer says this is okay. Their reasoning is that (1) the losses in the system due to line losses and losses due to extreme roof temperatures will cause the system to perform under this threshold even during the first year when the panels are producing at their optimum, and (2) the panels tend to degrade year after year. Hence, maximizing the capacity of the inverter will ensure that the panels produce enough voltage to run the inverter for as long as the inverter lasts.
If I change the inverter size to PVI-5000-OUTD-US-240, the configuration tool shows the "Inverter utilization ratio" of 95.2%. The dealer says that that might be little too high for the 15 panels, and suggests to stick with the PVI-4.2-OUTD-US-240 model.
I am not fully convinced of their argument. What do you guys think - does the lower size of the inverter really make such difference ?
Thanks in advance.
Thanks in advance.
