At my cabin I have 2x120 watt 17.8 volts in circuit at 6.8 amps each Suntech solar panels on my shed that have a MC4 connectors, and I connected a 48 foot (48' from panels to battery) 8 awg wire with MC4 connectors to the panels which leads to a 20 amp fuse and then goes to a PWM 25 amp charge controller. Connected at the 20 amp fuse I have a 15 watt solar panel 21 volts in circuit at 1 amp with 12 awg wires 38' from the battery, wired to the 2x120 watt panel's 8 awg wires. I did this because in the winter the 2x120 watt panels will be covered, and the 15 watt panel is mounted Vertically so it can feed power to the 110 ah battery during the winter when nobody is at the cabin to clear the snow. From the 110 ah battery I have 6 lights totaling 24 watts with 12 awg wires and a 1000 Watt inverter with 2 awg wire (inverter to battery is 17'). Now when I connect the whole thing the wires never got warm and everything seems to work great. Can this make the solar panels so hot I can't even touch them for a split sec? I do have the panels in a wooden framed box covered by plexiglass to keep people from throwing rocks directly as the panel and branches from falling on the panels. I was wondering if this is the only reason why the panel would get hot.
I'm not sure if this can be viewed, but I have a pdf of what I have wired here, http://joeytclements.com/cabinmay2012.pdf
and the box here http://joeytclements.com/solarpanelshed.pdf
