Requirement : To light a 20 - 25 watt DC 12v lamp for 7 hours a day
Hello friends.. I just wanna make a simple solar powered outdoor light for my farm house where there is a frequent power cut. The temperature is generally very high in my place Today the temperature here is 109 degree.. Iam a complete newbie when it comes to this project. I have read an guide by Jeffrey Yago from the following page :http://www.backwoodshome.com/articles2/yago92.html.
From this above guide, i came to an understanding that it requires 4 main components to go ahead with this project. 1. solar array 2. charge controller 3. a battery 4. DC Lamp.
Think we will be having 10 to 11 hours of full-equivalent sunlight.. So, now i will be needing a say a 75 watt solar panel. So, for 75 watt panel with 10 hours of equivalent sunlight, what is the capacity of the battery should i look for?? Would a 26Ah battery do the job for me?? Also, please give me a fair idea about which lamp i should go for.. Guess, i should look for some efficient 12v lamp as the battery voltage is 12v And i dont wanna spend on inverter.
Here goes the calculation part :
Bellow is the specification of the 75 Watt panel that iam planning to source :
[QUOTE]ELECTRICAL CHARACTERISTICS : SS-75
Nominal Power (Pm) in Watts : 75
Open Circuit Voltage (Voc) in Volts : 21.0
Short Circuit Current (Isc) in Amps : 4.76
Voltage at Maximum Power (Vmp) in Volts : 17.0
Current at Maximum Power (Imp) In Amps : 4.41
Maximum System Voltage : 1000V
PHYSICAL PARAMETERS
Solar Cells per Module (Units) : 36 Length X Width X Thickness (LXWXT)
in mm : 900X675X35 In Inches : 35.4X26.6X1.4
Weight in Kg : 7.95
Mounting Holes Pitch(Y) in mm : 450.00 In Inches : 17.7
Mounting Holes Pitch(X) in mm : 629 In Inches : 24.8
Area in Sq. Meter : 0.61 In Sq. Feet : 6.66
Junction Box : IP 65
OTHER CHARACTERISTICS
Type of cell : Mono / Multi crystalline Silicone
Front Face : Tempered Glass (Low Iron)
Encapsulate : EVA (Ethylene Vinyl Acetate)
Frame : Anodized Aluminium
Junction Box : Weather Proof Nylon 6
Temp. Coefficient : Voltage: -0.123 V/
Solar array having a 75-watt nameplate rating could generate 750-watt hours (75 watt x 10 hours) of power during a very sunny day. A 15-watt fluorescent lamp would operate 50 hours on this energy (750 watt-hour/15 watts), assuming no efficiency losses.
To Power a 15-watt fluorescent fixture an average of 7 hours each night. (15 watts x 7 hours)/ 12 volts = 8.75 amp-hour/day
Loss during both the battery charging and battery discharging process, and additional efficiency losses for the fluorescent ballast, charge controller, and wiring, adding at least 30 percent more to our initial calculation. (8.75 amp-hour) + (2.6) = 11.35 amp-hour/day
PHYSICAL PARAMETERS
Weight in Kg : 7.95
