Hi
I would like to power the following with a solar system:
A laptop @ 75W for 6 hours
Surround sound @ 70W for 4 hours
Lights @ 30W for 6 hours
Chargers @ 20W
Bass amp @ 400W 1 hour
(total 1400 W - ish!)
Using this site, I've calculated that, with an average of 5.5 hours sunlight a day, two 105Ah batteries should work for this; that a 650W inverter should do the trick; that 300 W panels should be enough to charge the batteries; that a 10 or 20 A controller/regulator is needed.
Questions:
1) Is the calculation correct?
2) 10 or 20 A controller?
3) What will I need to do in order to wire only the lights DC?
4) What do I need to consider if I would like to add a wind turbine into the mix sometime in the future?
5) (This might be asking a bit much, but...) If this were the site you were using to purchase the parts, what would you order in order to achieve a balance between efficiency, ease, and cost?
Respect,
Whazzatt (?)
Chargers @ 20W
Questions:
Respect,
Whazzatt (?)
