Most Popular Topics
Adding Panels to existing system
Cool. I've never seen that done, ever.
If you have a shaded panel, move it, it's useless in the shade. No need to buy another panel to go in parallel with it, when both are in sun, the rest of the string will throttle the power back to what only 1 panel produces.
These arrays have to be designed, not just " throw stuff on the roof till something works"Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Not so easy
I didn't design it. I am just the home owner. Unfortunately, I also know a little bit about physics and electronics. Until I convince the city that their panel placement restrictions are ill-advised, I have to live with the roof I have. The panel begins around 3 to be shaded. As long as the diode across the shaded panel holds up, it may not be worth worrying about. Maybe in the winter...Cool. I've never seen that done, ever.
Many thanks for the help.Comment
At three in the afternoon you are beyond prime time the losses are going to be not great.NABCEP certified Technical Sales Professional
solar rebate
when you added more solar you are able to write that off on your taxes right? state and federal? cause I am thinking of upgrading mine.Comment
