[QUOTE=Ronald McDonald;40053]OK what is the UL #. I will copy and print the white paper listing right here to settle it.
No Number = No Listing = BS.
Easy solar?
Thanks Rich, a copy of the UL compliance approval was checked by me already, and looks legit. Also, I called several electricians and engineers who checked their system against NEC codes and found it complies, ordered one kit todayLeave a comment:
This is a company wanting to be tricky to get sales - damn safety and play with the truth.
I would never consider buying from a company that I know is providing misleading information. They have a disclaimer providing a more correct way to go about things but to someone that knows nothing about electricity or code it would appear to be OK to just plug into any outlet and you are ready to go. That covers at least half the population and I would guess closer to 90%.
Do as they say and one is asking for problems with the utility and insurance company in the event of a problem.
Thanks, Ronald[/QUOTE]
The best thing for you to do Ronald is to get the white paper and approval from UL or other certified testing lab. The Manufacturer should be able to provide this. If not then I would not have too much faith.
You can also look up the electrical codes in the NEC and verify if this is an approved installation. This is available online. the article is 690Leave a comment:
1. Don't show the plug as they do on the main page - that is not a legal method
2. The comparison with hot coffee is silly - anyone that is not smart enough to know coffee as served is hot is better of dead anyway. Electrical installations are a different story - most will not read the manual but use the plugin provided.
3. The panels are UL compliant - stupid to sell any other kind - same goes for the microinverter - I don't know that they could buy a microinverter top sell that isn't compliant.
4. This company is selling EXACTLY the same thing as everyone else (except for the stupid plug) but they are trying to make it seem they have something easier and special.
5. This bunch manufacturers UL compliant microinverters? No - that means company can buy the same thing.
6. Lean them against the deck and make power - beyond stupid. 120 volts and connected into the household system is plenty deadly.
I think you are a shill for the company? If so say so. If not then why try to justify the 'stuff' this party is trying to hustle?
I wouldn't recommend this to someone I detested - pure fact.Leave a comment:
Thanks, RonaldLeave a comment:
Now the site says UL listed inverter. However they still show the standard plug on the main page.
Do as they say and one is asking for problems with the utility and insurance company in the event of a problem.Leave a comment:
So is there a DIY grid tie solar kit that meets all the codes? I'd like to get started in solar power and it would be nice if I could tie it into my home electrical system, so my fridge and air conditioner and other appliances could use the solar power if available. Is the best way to do this, is to hire a solar power professional installer?
Depending on your location and the restrictions of the local AHJ you may be able to do this on your own. Some Jurisdictions will allow an owner to work on their own house. I know where I live I cannot do so. Some distributors such as Solartown our host will sell a kit that you can install. Bolting the modules down is kind of a DIY project if you have the skills. I would still hire an electrician to do the connections. A micro-inverter system lends itself best for a DIY application.
Also check with your state for rebates which may only be available if done by a licensed solar contractor.Leave a comment:
So is there a DIY grid tie solar kit that meets all the codes? I'd like to get started in solar power and it would be nice if I could tie it into my home electrical system, so my fridge and air conditioner and other appliances could use the solar power if available. Is the best way to do this, is to hire a solar power professional installer?Leave a comment:
You are talking about a snorkels like these right? They are recessed inside a housing where you cannot come into contact with them.
However they do get a bit pricey. Probably cost as much as the panel and inverter.Leave a comment:
The basic thing - if you make the connection to meet code (considering all is UL compliant) you end up with a standard grid tie system.
Once you take the picture of the plug out there is nothing different or special.
Anyone selling microinverters and panels would have the same product.Leave a comment:
Not trying to bust your chops, but boats, RV's, etc fall outside the scope of the NEC. Those applications has a different set of codes and standards to follow.Leave a comment:
NEC 690.4 (B) You can't mix PV and non PV circuits in the same cable or outlet.....in other words, the receptacle on the wall circuit can't be used for anything OTHER than a PV conductor.
( copy and paste is from a PDF file, and is a bit odd...sorry)
(B)ConductorsofDifferentSystems. Photovoltaic
sourcecircuitsandPVoutputcircuitsshallnotbecon-
tainedinthesameraceway,cabletray,cable,outletbox,
junctionbox,orsimilarfittingasconductors,feeders,or
branchcircuitsofothernon-PVsystems,unlessthecon-
ductorsofthedifferentsystemsareseparatedbyapartiti on.
PVsystemconductorsshallbeidentifiedandgroupedas
requiredby690.4(B)(1)and(B)(2) [ROP4-184]
609.17 All PV systems must have a disconnect prior to the point of entry to a building....I seriously doubt "pulling a plug" qualifies. The AC disconnect must be clearly marked with signage per this section, listing the type (DC/AC) voltage, and amperage.
The correct definition of a source circuit would be the circuit between the modules and and a combiner or junction if less than three strings.
An output circuit is the circuit between the combiner or junction if less than three strings to the inverter.
A disconnect is not required unless DC is entered into the building envelope at the closest point that is accessable there shall be a disconnect and all DC wiring within the building envelope shall be installed in metallic raceway.
Since the output of this device is AC I would have to look for more reason to disqualify.Leave a comment:
609.17 All PV systems must have a disconnect prior to the point of entry to a building....I seriously doubt "pulling a plug" qualifies. The AC disconnect must be clearly marked with signage per this section, listing the type (DC/AC) voltage, and amperage.Leave a comment:
