Hi,
I just got two free ASE-300-DGF/50 panels (no micro inverters). I already had a basic Harbor Freight 45 watt setup, and a inexpensive 250 grid tie inverter working. I also have a small 600w and 300w inverter. Now I'm trying to figure out the best way to add the two new panels. Far as I can tell the specs for the new panels are:
Power (max.) Pp (watts) 300 W
Voltage at maximum-power point Vp (volts) 50.6 V
Current at maximum-power point Ip (amps) 5.9 A
Open-circuit voltage Voc (volts) 63.2 V
Short-circuit current Isc (amps) 6.5 A
My goal is to go off grid some day, but for now I just want to reduce power consumption, and have a really good backup power solution. I suspect that I will need to replace the charge controller first, but any feedback would be great.
Thanks,
Sanford
Thanks,
Sanford
