A lot would depend on what your "back-up" power system was intended to do.
f you want to power your house as if nothing happend, that is one thing.
If you are trying to ride through a brief outage and keep a few things running, that is a completely different objective.
If you want it all to happen automatically, that is one thing.
If you don't mind pulling stuff out, running some extension cords and such to get through a 12 hour to a couple of day outage, then you have a different situaion and a much lower up front investment.
So, what is your goal? How completely do you want the house to run? How automatic does it have to be?
You can have a separate panel in the house that is only touched by the generator and/or batteries. Or you can just run inverteres or a generator with extension cords to keep up the fridge, a sump pump, a TV and a couple of lights.
Big $$ difference across all these options. And where and how you tie in the solar PV panels will change too.
First set the goals and the budget. Then define the solution.
Seems I wouldn't be alone in that eh?
