  • Actonite
    • Dec 2025
    • 18
    Need help choosing Longi Hi-MO X10 panels
    My present solar array is within a few years of the end of its life, so I'm researching replacement panels. I'm having difficulty getting accurate information about Longi panels. When I ask Longi, they just send me a link to their installation manual. Hopefully, people here are familiar enough with their product line to recommend specific model numbers. Here are the features I'm interested in: Shading Optimization: High efficiency: Low Temperature Coefficient; Low Degradation: Anti-dust: Back Contact. I have no need for anti-glare or bifacial features. I'm looking to get the biggest bang for my buck. I can go as large as the 72-cell version. My inverter is a Sunny Boy SB6000US, so I can input as much as 7500 watts from the solar panels. I've attached a photo showing the present panels shaded in the afternoon, along with a diagram showing how 72-cell panels could fit on my present rails. I live in the foothills of the high desert in north Los Angeles Country, California. I get snow and triple digit temperatures. Any suggestions would be appreciated.
  • organic farmer
    • Dec 2013
    • 686
    Originally posted by Actonite
    My present solar array is within a few years of the end of its life, so ...
    What year was your system installed?
    I am curious to hear how you calculated that your system is nearing its lifespan.
    From my observation, modern installers are NOT craftsmen. Their business model is one that includes site assessment, system design and installation.
    Anyone who already has solar power in operation will likely never be able to get an installer to respond.
    They would rather contract someone else to rip-out your system, so they can do a fresh install.
    • Actonite
      • Dec 2025
      • 18
      My present system was installed over 20 years ago. I'm seeing a reduction in energy produced, so I know it's just a matter of time before it needs to be replaced. I'll wait till I'm down to 5kw / day before pulling the plug. Two panels have already died on me, and the prorated warranty paid pittance. Here you can see how shading reduces the afternoon production with my present panels. It should be a better bell shaped curve.
      You're right that most modern day installers aren't craftsmen. They just install what they're used to installing rather than researching the latest innovations. I don't have any problem finding installers to change out my panels. It's a simple job I could do myself, but I'm too old to lug these panels up on the roof. I guess I could hire a day laborer to bring my old panels down and take the new panels up. It makes no sense to remove fully functional rails the old panels were installed on. One company gave me a bid, but that was for Canadian panels, which don't have the shading feature and don't measure up to Longis in any area other than warranty. I am surprised Longi doesn't give a longer product warranty. Their power warranty is 30 years, like most others, but their product warranty is half that.
      • organic farmer
        • Dec 2013
        • 686
        I have a neighbor whose system was installed in the 1980s. His battery bus is all 12vdc. The system uses a $4 Chevy voltage regulator, he keeps old car batteries in parallel. The house is all wired in 12vdc. He got household appliances from RV dealerships. It is a nice house. But his home stereo is tube radio from a Chevy Impala. If you spend time monitoring and maintaining them, photovoltaic arrays can last a long time.
        • Actonite
          • Dec 2025
          • 18
          Newer solar panels are much more complex than the simple models of the past. They all degrade over time, and they're even rated on degradation. You're not going to see a 50 year lifespan, no matter how you maintain them. Most people are not willing to limit their home's electricity to 12VDC.
            • 5247
            My system was built in 2013, using then industry 6 X 6 in cells, in panels of 6 X 10
            or 6 X 12 cells. Since both of these are the same width, the system is set up to
            use either size, 12 smaller or 10 larger panels. The problem today is, the industry
            has gone to cells larger than 6 X 6 in, so current panels will not fit directly into
            my system. Panels also tend to be larger.
            So I think you will be dealing with this type issue, and must see what current
            designs can be fitted into your physical system. The voltage must also be
            considered, esp if using the same inverters as before. I did buy an extra spare,
            but now that a tree broke one, I run with no spare panels.
            To me the brand is not a primary consideration. good luck, Bruce Roe
            • Actonite
              • Dec 2025
              • 18
              I have a lot of flexibility when it comes to size of panels. I'm more interested in the shading feature that comes with Longi or Aiko.
              • Actonite
                • Dec 2025
                • 18
                I discovered Longi doesn't sell in the USA, so I no longer need this information.
                • scrambler
                  • Mar 2019
                  • 524
                  You can add Tigo optimizer to any panels to optimize shade issues and get individual panel monitoring
                  • adrianfen45
                    • Oct 2026
                    • 11
                    The Tigo route is probably the practical answer now that Longi is off the table. I would just check the optimizer count against what the SB6000US can handle on the DC side, since a unit per panel also adds a little standby draw and a lot of extra connections up on the roof that you will own for the next twenty years.
                    On a system that old, with two panels already dead, I would also confirm the rails and clamps will take the larger frames before committing. The current 72 cell modules have grown in both directions, and Bruce's point about width is the one that usually kills these swaps.
                    Aiko is still worth pricing if you want the shading tolerant cell layout, though availability in the US seems to move around by quarter. If you are holding out until production drops to 5 kW a day, you may get a few more winters out of what you have before anything has to change.
                    • Actonite
                      • Dec 2025
                      • 18
                      Are you saying Aiko may be available to me in the US? Aiko says they're not available. Let me know how I could coordinate those.
                      • adrianfen45
                        • Oct 2026
                        • 11
                        Following along. I've had a similar experience and it's always useful to compare notes.
                        • chandrapalmehula
                          • Oct 2026
                          • 4
                          When you are choosing between versions of the same panel family, line up the datasheets on the figures that change the design, not just the headline wattage. Check open-circuit and maximum-power voltage at the lowest morning temperature you get, and keep the string inside the inverter's MPPT and Voc limits with a bit of margin.
                          Also compare temperature coefficients, weight and physical size, because a slightly higher wattage module is no help if you lose a panel on the roof. If one option is bifacial, only count extra rear yield if the surface behind it is genuinely reflective.
                          Ask for the exact model code and the warranty document, and make sure the installer is happy to mount that module. Once the electrical window and the roof layout both work, the rest is usually split-hairs.
