  • Colton
    • May 2026
    • 4
    What are you using as a dump load for excess Anker E10 solar production
    Clipping about 8-10kwh of solar production every sunny afternoon because my Anker E10 with 2 packs is full by 1pm and I have nowhere to put the rest. No net metering in my area so it's genuinely wasted. Looking for ideas on productive dump loads that can absorb afternoon excess without costing more to install than they save.
    What I've considered: Heat pump water heater, probably the best ROI since I'm paying gas for hot water now. A 50 gallon HPWH uses about 3-4kwh per day and a timer could restrict it to solar surplus hours. But install means running a 30A circuit and doing the plumbing swap. Resistive element in a buffer tank, cheaper to DIY but less efficient. Could dump 4.5kw directly into a tank with a relay triggered by battery SOC. 3rd battery pack, $2,500 before credit. More storage but I'd still fill 3 packs by 2pm in summer and have the same problem.
    What are other people doing with excess? I feel like I'm leaving money on the ground every afternoon.
  • Reinne
    • Feb 2026
    • 4
    HPWH is the right answer for most people. Mine absorbs about 3.5kwh per day running exclusively on afternoon excess. I have it on a smart plug that only powers on when the battery hits 100%. Payback was about 18 months compared to my old gas water heater. Free hot water from april through october. Install cost concern is valid but if you already have a gas water heater you might have a 240V circuit nearby for the dryer or range that an electrician can branch off. Mine was a half day job.
    • Colton
      • May 2026
      • 4
      The smart plug triggered by SOC is clever. Are you doing that through the Anker app or a third party monitor?
      • Reinne
        • Feb 2026
        • 4
        Third party. I use a Sense monitor that detects when grid export starts, meaning battery is full and solar is surplus, and triggers the smart plug through Home Assistant. The E10 app doesn't have automation triggers unfortunately so you need something external to detect the condition.
