Well, We've figured out the correct Inverter to use with our System. Sadly, I need to do some minor re-wiring.
I need to remove Panel "A" (please see attachments). My question is: how to get on top of the other Panels to access surface of Panel "A" yet not damage them or (me) fall off the roof!
I think the best route would be to remove Panel "B" first, then Panel "A". I've got to access and remove the 4 bolt plates on each panel. Even with Panel "B", it's quite a reach to access the bolt plates on the lower end of Panel. Could I use plywood to 'belly crawl' to access these plates or use a ladder, laying it down on the Panels?
Either with cable or rope, I could "tie down" either plywood or ladder from the top of the roof.
Any suggestions?
PS: sure, I could remove the adjacent panels from the end, I guess. Just trying to avoid that as all I need to temporarily pop up is Panel "A"
Any suggestions?
