I live in northern NJ and am finishing up the first year with my solar panels. This site has been invaluable along the way.
My array details are 46 panasonic panels (14.95kW) and 2 SE 7600H inverters w/ optimizers. More details here: https://www.solarpaneltalk.com/forum...ou-doublecheck
My PTO was on 2/6/20, and my utility set my default 'reset date' at the end of that billing cycle, so my solar bank was reset to 0 on 2/25/20. Below is the data on my solar production and usage since then. Production is calculated using solaredge's website data, and usage is calculated from my utility bills (by adding back my solar production). I don't have a consumption meter.
Based on this, I finished my solar year on 2/25/21 with ~1,868 KWH in the bank that will be paid out at wholesale (ie, "wasted"). My overproduction for the year was 1,396 KWH, but that will likely be closer to 0 next year since we had some renovations going on at our house this past year, where portions of the house (including appliances) were not being used as regularly.
We generally produce more than we use in the fall, winter and spring (since heat is natural gas), and use more than we produce in the summer (3 AC zones, 30k gallon pool with heat pump).
Given this pattern, the online anniversary calculator is suggesting I should set my anniversary month to right after the summer like September, when I've burned through most/all of my bank. https://docs.google.com/spreadsheets...gid=1225290037
This seems to contradict the general advice to have a reset date in the early spring. Can you sanity check this for me? Since my utility only allows me to change this one time, I want to make sure I get it right
Any other suggestions also welcome.
thanks
thanks
