  • kimo
    • Jun 2012
    • 35
    Solar soon in our future!
    I am trying to size the right solar system for our home here in Hawaii. I do not want to invest in battery storage at this time and I plan to pay up front for the system vs leasing it. Our utility company requires a curtailment meter on the system if it produces more electricity than we use on a average basis. Since recently installing AC in the house our usage has gone up 30%.
    So if we average 900 to 1000 monthly KWH we can go up to a 3.5kw system without needing curtailment according to their requirements. I got a bid for a 3.4kw 10 panel system and the price seems good and it gives us the option to expand the system and add a battery if we choose later on.
    Of course I would love to just go for the full solar pkg with a Tesla battery and 20+ panels. But other repairs and upgrades to this home are in the works so I want to stay on budget. I am trying to keep the solar investment under $20k and the 3.4kw system is just the right price at around $17K.
    Now after plunking in my info on pvwatts I am trying to decide if the small system is worth the savings we will get out of it. Pvwatts says it will produce on average 4500 to 4900kwh/year with a value of $1637.
    I would appreciate anyone's opinion/advice.
    Mahalo
    • 15186
    Wow. That is about a 10 year payback by my calculations.
    I have also run the numbers and for me a solar install between 6 & 7kw still has a payback of almost 14 years due to the low rate of about $0.09/kWh. Even with Net metering that makes it real hard for me to justify.
    I would think that with a rate around $0.34/kWh range it would be much easier to justify a solar pv system but if you can't sell back any amount back to the POCO the price is much more difficult.
    Maybe you can look at the cost of adding on the battery system some time in the future if they come down in price. At least then you won't be throwing away any kWh the system over produces.
    Unfortunately each person needs to decide what a solar pv system is worth to them and if it makes sense to spend the money there or somewhere else.
      • 15049
      Welcome to the neighborhood.
      Since your asking:
      1.) What array orientation and shading were used for the PVWatts modeling that produced 4,700 - 4,900 kWh/yr. system output ?
      I ask because I plugged in Honolulu. At 20 degree tilt and 180 azimuth with no shade, I got about 5,800 kWh annually for a roof mounted 3.4 STC system. I'm aware that HI has varying climates, some with a lot of rain/cloud cover. What's your zip ?
      2.) How long is the "average basis" time period you write of ? 1 month ? 1 year ? Something else ?
      3.) To be clear, is the 900 - 1000 kWh/month based on historic usage or estimated future usage with the newer A/C loads included ?
      4.) Once how the model works is understood, PVWatts can be a good model for preliminary design of PV systems with respect to long term average annual output, but I've found the estimates of the $$ value of PV production it pukes out to be less than satisfactory. Sometimes it's close, and your average per kWh cost may indeed be $0.351 as the model uses, but depending on how your electric rates are structured and how your usage pattern(s) interact with that structure, the PVWatts annual savings estimate can be misleading, particularly when multiple rate plans are available.
      I'd spend some time with your POCOs tariffs and rate plans and figure out annual POCO charges and any subsequent estimated long term average savings on a monthly basis.
      5.) From how I read what you wrote, sounds like the bid you got doesn't include storage.
      6.) I know stuff costs more in HI - you want nice, you pay nice - and I admit ignorance on the PV marketing situation in HI, but $17,000/3,400 STC W = $5.00/STC W seems a bit steep. That nice round $5.00/STC W figure also seems like it might be a wall throw.
      Decent systems in CA are running ~ $2.50/STC W before tax credit or so with some not too sharp negotiating.
      How many bids have you received ?
      7.) On getting more bids: Even if all the vendors are in kahoots on pricing, and they probably are, actively or tacitly, I'd still get a few bids - and not reveal competitors prices - that, BTW, being a sure fire way to lock in a price that's about $0.01less than the next lowest bid.
      People who do reveal prices do the vendors price fixing job for them.
      Doing the "price match" game amounts to the same thing.
      Decent vendors probably know where they need to be on price anyway, but sharing bids only makes their job easier and removes their uncertainty - an uncertainty that can only work in your favor.
      Think about all that from the vendor's side of the table.
      8.) Before getting any more bids - if that's what you choose - and if you haven't done so already, download a free PDF of a slightly dated but still info filled book: "Solar Power Your Home for Dummies", or buy a newer version hard copy at bookstores/Amazon. You'll get a lot of info that's useful in decision making, increase the probability of a more fit for use PV system, and get a usually overlooked side bennie: Your new found knowledge will help with vendor selection in that you'll already know the answers to questions you will be asking vendors. That can be of use when separating the wheat from the chaff in that it'll be easier to spot vendors who are trying to B.S. you.
      Take what you may want of the above. Scrap the rest.
      • kimo
        • Jun 2012
        • 35
        Mahalo
        With power rates that low I probably wouldn't bother investing in solar. Here it fluctuates between $0.32 & $0.35 khw. It appears to be a worthwhile investment if I can size it right for our usage.
        Thanks for reply
        • kimo
          • Jun 2012
          • 35
          Since your asking:
          I'm on the East side of Kauai so we get a bit more cloud cover here on average being this close to the wettest spot on earth, MT. Waialeale. I've owned the house a long time but only recently living here fulltime. So I cannot get a long term average on our monthly energy costs. But it did jump up considerably after running our new AC system on a daily basis. We are starting to cut back on the hours of daily use and turning the AC off if were out of the house for two or more hours.
          When I put in my info on pvwatts the only number I changed was the cost per kwh. I know the bid sounds high compared to CA rates but it is on par with others here according to people I talked to. The only other bid I got was a pre paid solar lease. It came in at just under $30k my cost after they get the tax credit. Now that is for a full PV system 22 panels and 2 LG batteries. If I wasn't against getting into a lease, that would be something I would consider more.
          Thanks for reply
          • bob-n
            • Aug 2019
            • 572
            I think that SunEagle was trying to say that paying $17K and saving $1637 per year, you would need over 10 years to break even. It will break even faster if you can subtract 26% of the $17K due to government incentives. I'm not sure if they will apply to you and if you considered them in your calculations.
            I have a friend in Hawaii who installed solar himself and saved a lot of money that way, but not everyone is capable or comfortable doing that.
            • kimo
              • Jun 2012
              • 35
              You are correct, I didn't include the tax incentives that knock a lot off this $17400 figure which will eventually make it more cost effective. Fed tax credit 22% and HI state credit 35% or max $5k, net cost @ $8500. Just over 5 years break even after applying tax credits.
              • PVAndy
                • 230
                As far as I know net metering is no longer an option for Hawaii's solar customers, they have two programs to choose from: “Smart Export,” which requires an energy storage system that customers charge during the day and use for power at night, and “Customer Grid Supply Plus,” where they can export power to the grid throughout the day but receive less-enticing compensation.
                Andy
                • kimo
                  • Jun 2012
                  • 35
                  Andy
                  I think you are correct, but each Island has different electric providers, each with their own requirements and solar incentives. Here on Kauai KIUC is our electric provider and is a cooperative. I am just learning as I go. I think there are times when they will buy excess solar generated power or give a credit for it. But I'm trying to keep my system affordable since not desiring a lease program and want to pay cash for it.
                    • 15049
                    Thanks for reply
                    Thank you. I suspected the weather variability may have contributed to the output variation.
                    Avoiding a lease is, IMO only, a wise move.
                    Side bar: Back in the day, I was the responsible engineer for a portion of a major equipment upgrade to a small diesel fired power plant on Kauai. One unusual challenge for that project was the strict noise abatement requirement for most of the equipment, including the silencers for the diesel generators. They (the silencers) were about 90+ ft. tall as I seem to remember and looked a lot like smokestacks or distillation towers. Fun project. There's a picture of the silencers in situ someplace on the net.
                    • PVAndy
                      • 230
                      I’ll be interested to find out what you learn. One of our engineers used to work in Hawaii
                      Andy
                      • kimo
                        • Jun 2012
                        • 35
                        I remember seeing stacks like that over by Port Allen Harbor. I think that is where the plant is? Yes never been much for leases, condo's or timeshares...lol
                          • 15049
                          Yea, the plant is down near the end of Aka Ula St. from my old project notes/punch lists note. I remember it was a bitch getting the equipment down that road. That's when I came to really appreciate that rigging is an art.
                          Each silencer shipped in 2 pieces - body and stack with wind strakes. Final fit up/welding/assembly done at jobsite.
                          My understanding is they later put a PV plant next to the diesel generating station and now use the diesel units as backup with a lower duty cycle.
                          Thanx for the memory jog. Glad to see some of my kids still standing after so long.
                          Back on topic.
                          • khanh dam
                            • Aug 2019
                            • 391
                            I thought tesla was offering $1.49 /watt solar on any roof?? I guess shipping panels to a remote island is not included?
                            Personally I would order a micro inverter kit and mount all the panels and hire an electrician to do the final ac hookup that would save the most money.
                              • 15186
                              The problem most people run into is that the electrician may not install hardware that you purchased or the local AHJ may not approve the installation.
                              You can save money doing yourself but check out all of the local requirements and codes before you spend any money.
