Just about to start finishing off the interior upstairs on our house. Totally spaced getting conduit into the walls for the grid-tie...
real quick:
21 panels run to a SB inverter. Plan is run two strings into the SB and leave one MPPT input open for a ground month array later.
should I run 1” or 3/4 Metal? And can I run the flex I able style or does it have to be rigid? Also for the output of the inverter since it’s AC, can I use PVC to the breaker in the house?
thanks!!!
real quick:
thanks!!!
