I think I'm finally done adding arrays to my system. I got one array on my shop roof and 5 smaller ground arrays for a total of 205 panels.
Shop roof mounted array consists of 56 265w panels each with a 250w micro-inverter on them arranged into 4 AC strings with 14 panels each.
Power curve:
2nd array is in front of the shop build and is a "pole-barn" of sorts where I keep my tractor implements. It consist of 45 275w panels. 36 of them are wired in 3 DC strings feeding into a Sunny Boy 7.7k inverter. The remaining 9 panels have micro inveters on them in a single AC string.:
Power curve from the Sunny Boy section of the above array:
I do have a bit of shading in the morning this time of year.
Next array is ground mounted next to the shop building and consists of 24 265w panels with micro inverters:
Next array consists of 32 275w panels arranged into 3 DC strings feeding another Sunny Boy 7.7k inverter.
Power curve:
The final array is separated into 2 sections with 24 280w panels in each. These are all using micro-inverters.
And yes, I managed to crack the glass on 4 of those panels when I used a stump grinder to trench for the pole barn array.
Power curve:
All the micro-inverter AC strings and the AC output from the Sunny Boy's all terminate in a dedicated sub-panel:
I had the power company come out and swap out my 25KVA transformer for a 50KVA one once I got past 25kw capacity.
I'm on net metering with the POCO so anything in excess that I generate builds up a bank of kWh on my account. Unfortunately my household use more than I generate still, but at least the 50kWh of capacity takes a big chunk out of it. Since adding the newest array (the pole barn one), I'm up to about 300 kWh per day, which is pretty good for this time of year.
If I had to do it all over again, I'd go all DC strings and ditch the micro-inverters. But live and learn I suppose.
Power curve:
Power curve:
Power curve:
