Hi All.
I'm a newby here, but I have been reading the forums for a while now planning my project.
I'm in the process of installing a new 32 panel ground mount at my home using Iron Ridge racking and Enphase mircoinverters. I'm mounting (16) panels each on 2 separate ground mounts a few feet apart (they are only split into 2 arrays due to the sloped nature of my property). The ground mount is approx. 230' from my home, my plan is to mount the Enphase AC combiner box inside my basement, and run (2) #4's out to each array. So far I have the racking up and I'm now waiting for a sunny day to get the trenching going.
However, I do have a question about grounding, and having read all the related posts and now I'm feeling more confused than ever.
Based on the Enphase documentation the microinverters don't require a GEC or EGC, however the Ironridge racking documentation suggests a single ground connection per array.
My plan was to run a ground wire from the combiner box in my basement out to the array with the conductors, however, the more I read the more I think this probably isn't the right plan, as it sounds like if there were a lightning strike nearby it could travel back to my house.
Should I be installing a ground rod for each array and bonding the mounting frame to ground that way? And if so I assume I need to tie the ground rod for each array together? And would it make sense to install a single ring around both arrays with a ground rod at each corner? Also, if I install ground rods at the arrays do I need to bond those ground rods back to my main service ground rod? This will involve an additional 100' of trenching as my utility ground is located on the other side of my house to where the conduits from the arrays will be entering my basement.
Obviously my main concerns are not setting my house on fire in the event of a nearby lightning strike, and also ensuring the whole mounting frame doesn't become live in the event of a fault condition or damage to the wiring.
Thanks in advance for any advice you may have for me.
David
David
