I've had great luck with my installer's knowledge, but this didn't quite add up so I wanted the proverbial second opinion. My system will have 38x390w LG N2W Panels producing 14.43kW. The original project was only about 12.4kW, but I had some higher usage needs while we were waiting on approval so we made the adjustment. It also has 38 P400 Power Optimizers.
Where I'm confused is the original system was only about 1kW above the Solar Edge 11.4kW (SE11400H) rating, and I was told since with 90% AC conversion I would only have a max theoretical of 11.2kW and it should work just find since they can handle a bit extra.
Since I've upped the system size I asked again as I'm at 14.43kW DC and 13kW or so max AC. The converter no longer appears large enough. The answer I got was that was SolarEdge's largest consumer model (that appears accurate) and 2 inverters will cause further losses from the additional connections. Does this sound correct? My panels are in such a way they all face the same way and get sun at the same time creating a huge spike during probably 4-6 hours of the day and much less other times. I'm feeling like I'm wasting money if I have quite a bit of trim during the hottest part of the day, Especially, since all the panels get or don't get sun at exactly the same time.
Please help!! Trying to finalize documents today and I've done a lot of research, but this is one area that was a little too specific to ask and probe with the right questions.
