Tied 36 .5volt cells in series and i'm getting 30 volts output. I should be getting 18 volts. I'm testing this straight off of the cell configuration. I do have a charge controller but i am wondering if that voltage will fry the controller. I will be charging 12 volt battery with this system. I don't know if this is normal without a load. I have enough cells to build 15 of these panels. Should i remove some cell? Won't that drop the watts? This panel should be 63 watts with 36 cells. Please help. Thank you.
Most Popular Topics
Tied 36 .5volt cells in series and i'm getting 30 volts output. please help
Never under estimate the power of hard work. In time something magnificent happens. Dreams are only dreams if you don't push forward. Have a productive day. Tomek. -
I take you you are measuring at open circuit voltage? If so you will need to have a MPPT controller with a 12 volt battery.MSEE, PE -
open circuit
if you mean nothing connect to the solar cell then yes i am testing it in open circuit. I have the controller. My ? is will 30 volt fry a 12 volt controller?Never under estimate the power of hard work. In time something magnificent happens. Dreams are only dreams if you don't push forward. Have a productive day. Tomek.Comment
Quite possible if it is a PWM controller. MPPT no problem. Check your controller spec for maximum Voc
FWIW if you do have a PWM controller and it can handle 30 Voc on a 12 volt battery you will will loose 60% automatically of your panel wattage. MPPT no problems.
Example lets say your panel is rated 60 watts with the 36 cells, you will turn it into a 24 to 30 watt panel. Loose 10 of those 30 cells and you have a 40 watt panel that will produce the same 24 to 30 watts.
A typical 12 volt panel has a Voc of around 20 to 22 volts (you have 30) and a Vmp of around 16 to 18 volts.MSEE, PEComment
ok so should i remove 10 cells
if i remove those cells then i can make more panels to make the watts up but why would the cells that are max rated at .5 volt make 30 volts with 36 in series. i can't find no spec on the charge control for the voltage all i found is 105 max watts and 7 amp max its a pulse controller cut out at 14.2 cut in at 13.0 .i have a bunch of these. I'm really sorry about bugging you about this. I'm pretty good with math but this one is not making sense. i tested each cell and i had a reading of .42 to .52 volts but ran in series i got 30 volts. just don't make sense. is it possible i got a very good batch of cells? Thank You so much for the help.Quite possible if it is a PWM controller. MPPT no problem. Check your controller spec for maximum Voc
A typical 12 volt panel has a Voc of around 20 to 22 volts (you have 30) and a Vmp of around 16 to 18 volts.Never under estimate the power of hard work. In time something magnificent happens. Dreams are only dreams if you don't push forward. Have a productive day. Tomek.Comment
vmp
what does that stand for?Never under estimate the power of hard work. In time something magnificent happens. Dreams are only dreams if you don't push forward. Have a productive day. Tomek.Comment
Home Power has a very good document that explains many PV panel terms -
1) PV module comparison http://homepower.com/view/?file=HP134_pg50_Sanchez
Russ[SIGPIC][/SIGPIC]Comment
thanks allot for the link. this will help me out when i will be buying my next panels.Home Power has a very good document that explains many PV panel terms -
RussNever under estimate the power of hard work. In time something magnificent happens. Dreams are only dreams if you don't push forward. Have a productive day. Tomek.Comment
Voltage @ Maximum Power
A solar cell has 5 specifications of interest to designers and 2 for a home owner.
Voc = Voltage Open Circuit. This is a static test of the voltage of the panel pointed directly into bright sun light with no load connections and one a homeowner can perform to check against factory specs. A typical solar panel made for 12 volt panels will measure around 22 volts
Vmp = Voltage Maximum Power. This is a factory test only, a homeowner does not have access to the equipment needed to accurately measure Vmp It is a measurment of voltage of the panel when it is producing maximum power at a specified irradiate input. A home owner can take measurements during the day to see if th epanel is loading properly and get an idea his/her panel is producing power or not and to check for malfunctions. Typical Vmp for a standard 12 volt panel is around 16 to 18 volts and will always be less than Voc
Imp = Current @ Maximum power. Again a factory measurement
Isc = Current Short Circuit. This can be done by a homeowner who knows how to operate a meter capable of measuring the intended current of a single panel or a string of series panels but can be dangerous. So only proceed if you fully understand the risk and principle. Otherwise on a large string array death and injury can occur. Th epanel is pointed directly into noon day sun and the terminal shorted out either through a shunt meter or a wire loop when a clamp-on hall effect meter is used. This current will be higher than Imp and used to check if panel is operating properly.MSEE, PEComment
thank you
you are right about the voc once a load was put on the panel (charge controller) it drop the volts down to 18.8 volts. thanks so much.Voltage @ Maximum Power
Isc = Current Short Circuit. This can be done by a homeowner who knows how to operate a meter capable of measuring the intended current of a single panel or a string of series panels but can be dangerous. So only proceed if you fully understand the risk and principle. Otherwise on a large string array death and injury can occur. Th epanel is pointed directly into noon day sun and the terminal shorted out either through a shunt meter or a wire loop when a clamp-on hall effect meter is used. This current will be higher than Imp and used to check if panel is operating properly.Never under estimate the power of hard work. In time something magnificent happens. Dreams are only dreams if you don't push forward. Have a productive day. Tomek.Comment
