We have a SolarEdge system that has two strings, but one of the strings seems to be down. While the system was installed in 2014 - we bought the house last fall, and I am still coming up to speed on some of this. The system has 39 panels, and is rated for 9.75kW, with a SE10000 inverter.
I can tell from the monitoring portal that the system operated correctly for all of 2015 - the output dropped by about 60% in May/Jun of 2016. This past summer, peak output was about 4kW.
I can look on the monitoring portal - I can see there is one optimizer that has not reported status since 6/25/16. Over 2 years, in other words. This more or less coincides with the power drop. There a few other optimizers that oftentimes are late in reporting - as I write this, anywhere from a day to a month late in reporting.
The remainder of the optimizers on the string are reporting on a regular basis, but they seem to remain in "Safe Mode" with an optimizer voltage of 1V.
The original installer is still around, but they are not all that responsive (I suspect they were slammed with new install business). I had booked the appointment in mid-Nov, and on the day of, there was a noreaster - there was no way anyone sane was going on the roof in that kind of weather. At the time they were inspecting any interior wiring and refreshing their memory as to how they did the install back in 2014 (mainly wondering how they routed the wiring through our rather unusual house). He wondered about whether the system was showing any fault codes - that's something that apparently I can't currently see in the management portal. He said he could grant me installer access, but that never happened. They said they were going to come out when the weather was better so they could go up on the roof, but I see no indication that this has happened either.
When they were here, they were kicking around various ideas. Mainly checking the connectors where they did internal wiring, but perhaps a bad ground on one of the optimizer? They had wondered whether one of the connectors for the string had popped off (if that had happened, wouldn't that imply that all of the other optimizers on that string would be unable to report??). I am wondering if a failed optimizer could take down an entire string. And I am curious as to why it is that a few of the other optimizers are having intermittent communications.
I would rather not go on the roof myself - my first choice was to have the original installer fix the thing, but I am wondering if I have a plan-B. Without installer access to the monitoring site, I am not sure what other options I really have - a different vendor probably wouldn't have the ability to configure a new optimizer, for example.
After that one day where they did come out, I got horribly busy with stuff, so I back-burnered the whole thing, but I thought I would ask here to see if anyone had any thoughts as to what the underlying problem might actually be. But my busy-ness is coming to an end, and I want to get something going here. In the next day or so, I guess I could call yet again and see if I can get the original installer to do anything at all.
Thoughts?
