  • georgia088
    • Sep 2018
    • 71
    more efficient 12v to 24v step up or 120v to 12v inverter?
    Hello, as I talked in another post, I am trying to run a ubiquiti wireless internet device off of solar panels. I would obviously like to do it as efficiently as possible. The devices come with a power adapter that is a 120v to 24v adapter. So, basically I have a 12v solar system. I am using a modified sine inverter to convert the 12v to 120v. Then the power adapter converts it from 120v to 24v. This seems like it has to be super inefficient. Would I be better off getting a 12v to 24v step up adapter? or not?
    Also, in a similar application, I am powering a camera with a power adapter plugged into inverter. The power adapter (plugged into modified sine inverter) drops the 120v to 5v. Would I be better off getting a 12v to 5v step down adapter?
    Thanks!
    Find out what the device actually needs. My wireless router has a 12V wall wart, and then an internal 5V regulator. Your gear may actually run on 12 or 9 or 5 volts.
    Otherwise, yes, you are stuck using 120VAC as your middleman. But you can use an efficient inverter like the Morningstar Suresine 300. I'll bet it consumes half the power of your current mod sine inverter. 0.45A idle.
    Experience reliable power with SureSine Off Grid Pure Sine Wave Inverters from Morningstar Corp.
      Seems simple to me, use a 24 volt system.
      • Logan5
        • Feb 2013
        • 484
        A number of After market equipment manufactures sell ubiquiti wireless DC voltage POE inserter to replace the AC to DC POE adaptor that comes with the device. If you run a 12v or 24v battery, you can connect directly to this inserter, negating the need for an inverter. Find them on Amazon and E-bay. I run a 24v battery for my ubiquiti wireless devices without any issues.
        • PNW_Steve
          • 433
          I have successfully run a variety of UBNT gear on 12 volts.
          Their earlier gear came with a POE injector that used an external 12 volt wall wart. Newer stuff has a built in 120 volt power supply in the POE injector.
          However, running on 12v we found distance limitations on the POE cable runs. As expected... .
