At the moment I am getting ready to put together a grid tie in solar system and I was looking for some advice.
I plan 15-330w panels specs:
Max voltage- 37.8V
Max current- 8.74A
Max fuse rating- 20A
Zeversolar 5kw, I havent got the inverter yet but I have some specs
max DC-5300w
Max input- 600V
MPP voltage range- 100-520v/360v
max input per MPP- 11A
2 MPP
I am guessing I would have to run 2 strings. String 1 is 8 string 2 is 7 panels. Would this be a problem not having an even number of panels? I could run 8/8 string but that would bring my
wattage to 5280watt when Max is 5300w. I was also going to have a separate breaker box per string with each having 10A DC fuse,16A breaker, 1000V surge and about 5 -6 meters between breaker box and panels. On the AC side not sure what the breaker will be yet looking into local laws, but advice would be good. One thing is AC line would be about 200 meters from the the grid. Would this be a problem with putting power back in?
Much appreciated for any advice you can give me.
Max voltage- 37.8V
Max current- 8.74A
max DC-5300w
Max input- 600V
2 MPP
