Ok, well the inspection passed today, and we officially flipped the switch on, at about 11:45am PT, was producing about 5.6kW, and netting 4.6kW (Pool pump is running + baseline consumption) to the grid according to the SolarEdge inverter, walked outside the garage to the meter, and it was netting right about the same (with a few Watts.) Had to get back to work, but should get my Metering (including Consumption Metering) all setup tonight so I can get the full detail instead of just panel display output. Then I write the check for the system.
That's slight more than what PV Watts suggested, but it's a nice sunshiney day. Can't wait to get a good bit more data and see if the loss values used were too conservative or not conservative enough.
