In California: In the end I believe that 'net' energy metering means what it sounds like, that it's symmetrical between production and consumption, with the explicit exception now of non-bypassable charges. What really matters is what the CPUC approves. Here is what SDG&E says on NEM-ST:
http://regarchive.sdge.com/tm2/pdf/E...EDS_NEM-ST.pdf
Look at section 3 a):
Baseline Rates: If the customer is a net consumer over a billing period, the net kWh consumed shall be billed at the applicable baseline rates up to the billing period's baseline allowance, with any excess kWh consumed billed at the applicable non-baseline rates charged other customers in the rate class. If the customer is a net generator over a billing period, the net kWh generated shall be valued at the applicable baseline rates up to the billing period's baseline allowance, with any excess kWh generated valued at the applicable non-baseline rates charged other customers in the rate class. Any nonbypassable charges, as defined in Special Condition 1 of this schedule, shall be billed based on the kWhs consumed in each metered interval net of exports.
