... now the "mystery wattage from panels" according to my eyedro consumes a solid .684 kwh... multiply that by the 6.5 hours i was gone and you get 4.446, the favorable 4kwh difference! it appears to me that my eyedro is functioning accurately, my meter socket is responding to the solar production and that this mystery wattage is not being considered delivered or charged... to further solidify this finding I am going to land the eyedro clamps on the pv taps overnight... I will see on my eyedro the .684 kwh draw from pv system constant. I will record the kwh number on my meter socket at night. compare in the morning to what the pv system drew for wattage overnight. Which after 8 hours is 5.472 kwh... if my meter socket reading does not go up according to what the eyedro shows the pv system drawing I will feel certain at that point I am not being charged for this .684 kwh draw.... Im still curious why its there though!
Pv system running watts
i will research my meter model... I have some numbers here... i left this morning at 915am my meter socket read 675 kwh delivered... my eyedro at that time read 6.33 kwh used... returning home at 345pm... 6.5 hours later... my meter socket reads 672 kwh delivered... my eyedro says 13.66 kwh used... my enlighten says I produced 6.36 kwh... so if I started with 675 kwh, my eyedro went from 6.33 kwh used to 13.66 kwh used... 7.33 kwh difference... my meter socket should read 682 kwh delivered (not considering panel production), it says 672 kwh... now i produced 6.36 kwh, that should come off the top of the 682 kwh reading, bringing it down to 676 kwh... im reading 672 kwh on meter socket... so there is a favorable discrepancy of 4 kwh on my end...
Your utility meter only shows NET and by delivered they mean you purchased from them.
so this morning it read 675kWh and latter read 672kWh so you had a NET reduction of 3kWh
Your enphase system shows you generated 6.36kWh. This means that your house consumed 3.36kWh before it could be sent to the grid.
( this comes from the 6.36kWh generated plus negative 3kWh NET = consumption)
your eyedro is reading a gain in consumption of 7.33kWh because it is not very accurate, doesn't account for direction, Voltage changes, etc.
It should be reading negative 3kWh but it doesn't do direction so no negative values, everything is additive so worthless in your use case.
I don't know where you came up with "682 kwh delivered"
Your confusion seems to be in putting way too much stock in that eyedro.Last edited by ButchDeal; 02-01-2018, 05:03 PM.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
https://deckmonitoring.zendesk.com/h...c-Socket-Meter
check it out, my meter instruction manual. chapter 2, displays... i was suppose to have an option at time of order to choose what displays i would like to see on my meter face. The disc-emulator looks interesting. I believe I am set to the Delivered - Recieved energy modeComment
i started with 675kwh... my eyedro says i used 7kwh... my panels produced 6kwh... the mystery wattage equals 4kwh... 675 + 7 = 682... 682 - 6 = 676... 676 - 4 = 672kwh which is what the meter socket says. The eyedro is reading this .684 kwh the pv system draws constantly. I double checked this using my Ideal amprobe seeing 3.14 amps being drawn... This .684kwh is not being recognized by the meter socket, even though it is there always. day or night.Comment
The "customer" referred to in that manual means the POCO, not you.https://deckmonitoring.zendesk.com/h...c-Socket-Meter
Your eyedro has no way of knowing what you used or actuall consumption. For that it would need two sets of CTs on on the Net side and one on the inverter side, and it would have to understand negative numbers. It doesn't.
Again your measurement method is not accurate. you are only measuring one leg to neutral each. The meter is measuring leg to leg
The enphase monitoring is saying that it produced 6.36kWh and that would include any self consumption of the inverters.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
ok, so the enphase monitoring includes any self consumption of the solar system. its number of production today being 6.36, wouldnt my reading go from 675 to 669 on meter socket? I found it at 672. which means over that 6.5 hours my empty house with no lights on, no appliances, not even the furnace running consumed 3 kwh of power to get me to the 672 i see? if that is the case then i would be lead to believe the solar panels are consuming a large amount of wattage.Comment
I mean I have used two test instruments, the ideal amprobe I have the highest confidence in and both measurements corroborate the other, simple math... the .684kwh according to eyedro we can translate that to the same number I am reading with amprobe. the amprobe read 3.14amps.... 3.14 x 117volts = 367 watts... 367 x 2 legs of power = 734watts... eyedro reads 684 total watts both legs, amprobe reads 734 watts both legs. within range of one another for any measurement tool with expected slight deviance. This .684 from the solar was read at night remember, no production available whatsoever.Comment
you have a base load in your house. Everyone does. Wall chargers consume, TV boxes, alarm clocks, refrigerator, etc.ok, so the enphase monitoring includes any self consumption of the solar system. its number of production today being 6.36, wouldnt my reading go from 675 to 669 on meter socket? I found it at 672. which means over that 6.5 hours my empty house with no lights on, no appliances, not even the furnace running consumed 3 kwh of power to get me to the 672 i see? if that is the case then i would be lead to believe the solar panels are consuming a large amount of wattage.
Some people have gone to (extraordinary ) lengths to get their base load down. but you have some base load. 6.5 hours and 3kWh is 462wh (0.462kWh) per hour or 462w . Mine is right around 400w
It isn't your solar panels or enphase inverters it is all the little things in your home and some big ones here and there.
yep and it is just not telling you what you think it is telling you.I mean I have used two test instruments, the ideal amprobe I have the highest confidence in and both measurements corroborate the other, simple math... the .684kwh according to eyedro we can translate that to the same number I am reading with amprobe. the amprobe read 3.14amps.... 3.14 x 117volts = 367 watts... 367 x 2 legs of power = 734watts... eyedro reads 684 total watts both legs, amprobe reads 734 watts both legs. within range of one another for any measurement tool with expected slight deviance. This .684 from the solar was read at night remember, no production available whatsoever.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
ok, the base load example makes sense, I certainly am considering it now. I gotta say though I dont understand why my amprobe would read 3.14amps, never mind the eyedro, on my main feeds with the only thing turned on is the pv system, at night.Comment
I suspect that the enphase micros are doing some powerfactor correction and moving power from one leg to the other to do it. They do claim to help correct powerfactor issues which is required in some markets for smart inverters.
The capacitors in the Micros will give your Eyedro and amprobe false readings.
Tonight turn off every breaker except the solar and the main. Record the reading on the POCO meter before and after several hours....divide by time.....now you will see true usage.Comment
could these false readings be found on the branch circuits? why would it stop at the main breaker?Comment
