My suggestions to the OP:
1. Can you get a 2nd separate service for your castle ? say your in-laws / servant / peasant accommodations ? That way you can you can get 2x 25kW systems.
2. If above doesn't work, I would take a serious look at reducing your consumption. Its always cheaper to use less. Upgrade HVAC, Pool Pump, W/H to be more efficient. Upgrade the heck out of insulation / windows etc
3. Another option is to add an off-grid system on top of your 25kW grid tied system. Move predictable day-time loads like pool-pumps, water-well etc. to the off-grid system with a smallish size battery backup.
I would find out if 25kW limit is on the AC size of DC size. If it is AC, then by all means, get a 30 to 35kW DC system with an AC output limit set at 25kW. Your system will exceed 25kW 1% of the times so not much will be lost.
Good-luck.
Good-luck.
