More Chi-Com Junk from Karrak.
Clamp-Ons are great for Verification and testing for DIY's and even pros. But you giv eup accuracy at their lower ranges. For bench testing or other accurate applications use a SHUNT. A Shunt is nothing more than a precision Power Resistor and scale to 20, 50, and some 100 millivolt full scale at about any current range you want from 1-Amp to 1000 Amps. All it takes is a good accurate volt meter to use. You can even buy a decent Panel Volt Meter if you are making a test rig.
If you want Chi-Com use a Hobby Power Meter. for $10 to $40 measure everything. They use a Current Shunt. You can measure voltage, current, power, amp hours, watt hours. Or as Jeff says if you want a Clamp-On both Blue and Orange Box stores sell them in the electrical dept. At least if they fail, you can get a refund or replacement easily, and someone to sue if need be. .
