Most Popular Topics
Looks like SolarEdge HDWave inverters will have secure power like feature
BTW, SMA has upped their secure power rating to 2000 watts.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Yes I know. SMA was mentioned early in the thread.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
The DC disconnect looks revised in the HD-Waves. Expecting HD-Wave integration with Powerwall 2 DC? 7600W version only again? Seems Powerwall 2 AC might be the path of least resistance if it will work in the desired mode (mobile off-grid for example).Comment
I believe the current powerwall 2 will not work in an off grid mode.Comment
I've gotten this thread a bit off topic, but I talked to Solaredge tech support about the rapid shutdown feature. The SE series will only do rapid shutdown if the DC disconnect is turned to off. If grid power is lost the inverter will shut off DC voltage within 60 seconds. I did not ask about the HD-WAVE with the backup power feature.Comment
If the HD wave is in secure power and someone shuts off the DC disconnect then it will rapid shut down.
OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
I believe it will, based on their website now saying "Your path off grid - Combine solar and one or more Powerwalls to power your home independently from the utility grid." I think there have been questions about warranty when using off grid or warranty use is not monitored. But it is hard to judge without an installation manual - certainly marketing people have made bigger mistakes.Comment
All previous versions were based on using it to run at times when the POCO tariffs are very high so you could reduce your bill not as an emergency backup. There was a unit in the first version that was rated 10kWh and to be used as a backup power source. That unit is no longer being offered. And the smaller unit was originally rated ~ 7.5kWh and now it is in the 6.4kWh range. I believe it was derated to comply with the "promised" cycle count. You now have less to use but can use it daily for what ever the published lifespan is.
If they are now marketing an off grid version of the Powerwall it is news to me.
All previous versions were based on using it to run at times when the POCO tariffs are very high so you could reduce your bill not as an emergency backup. There was a unit in the first version that was rated 10kWh and to be used as a backup power source. That unit is no longer being offered. And the smaller unit was originally rated ~ 7.5kWh and now it is in the 6.4kWh range. I believe it was derated to comply with the "promised" cycle count. You now have less to use but can use it daily for what ever the published lifespan is.Comment
But I thought that one was for grid stabilization/peak shed use only and not for back up. Maybe there is a couple of P2 variants.Comment
I know that one of the POCO's in Vermont is introducing the Powerwall 2 to customers with solar pv installations. They can either lease it or purchase it.
Last edited by littleharbor; 01-18-2017, 10:06 AM.2.2kw Suntech mono, Classic 200, NEW Trace SW4024Comment
Specs are somewhat vague but it looks like the DC voltage of the Powerwall2 are 50 Volts while the Powerwall 1 was 350-450 volts Please correct me if I'm wrong. It appears the Powerwall 2 is off-grid compatible.
Spec sheets for PW 1 and 2:
http://www.treehugger.com/clean-tech...arting-3k.html
Also the spec sheet for the P1 is defiantly out dated since the 10kWh model for backup power was discontinued or for that matter did not even go into production and the 7kWh was downsized to around 6.5 kWh.Comment
