I was checking some specs on the inverter i got (a duralast 200 W) and it states that it uses less than 0.4A per hour when NOT under load. Can someone tell me if that is 0.4A at 110 V? I mean if it is hooked to the battery and switched on is that 0.4 A draw from the batter per hour when on but not in use?
I plan to use it part time and will have it hooked up to a digital time i purchased. The inverter will make a beeping noise should the batter voltage drop and i believe it will not stop beeping until i reset it or increase voltage. I can not be resetting it all the time. and i do not want it to drain when not in use.
If i add the timer before the inverter and should it be such that voltage drops and it starts to beep will it resent when the time switches it off and back on some hours later or does the actual inverter on/off has to be used.
Not sure if i am making sense lol!
