Apologies: this has been discussed quite a bit even lately but probably there's a slow dribble on it always.
Still I'm not sure how (and have searched fruitlessly to find how) $/W is calculated from the CSI database because there are so many technical ways of estimating power.
Is one of the following the correct denominator? Someone elsewhere discussed that they felt AC rather than DC was a better scale but I think there's a convention to this, no?
TIA
Or instead one of these?
Nameplate Rating | Direct current output of photovoltaic module under Standard Test Conditions in kilowatts |
CEC PTC Rating | Alternating current output of photovoltaic module under PVUSA Test Conditions in kilowatts |
Design Factor | A ratio comparing a proposed systems expected generation output with that of a baseline system |
CSI Rating | Alternating current output of photovoltaic module calculated by multiplying the CEC-PTC Rating with the Design Factor |
CEC PTC Rating Fixed | CEC PTC Rating of the fixed array portion of the project |
CEC PTC Rating Single-Axis Tracking | CEC PTC Rating of the single-axis tracker portion of the project |
CEC PTC Rating Dual-Axis Tracking | CEC PTC Rating of the dual-axis tracker portion of the project |
CSI Rating Fixed | CSI Rating of the fixed array portion of the project |
CSI Rating Single-Axis Tracking | CSI Rating of the single-axis tracker portion of the project |
CSI Rating Dual-Axis Tracking | CSI Rating of the dual-axis tracker portion of the project |
