Most Popular Topics
How did you decide? Microinverter vs Optimizer & PV Inverter
Let me ask this of ButchDeal (or others who may have an opinion):
Earlier on this thread you mentioned that: "Of course SolarEdge would be cheaper than enphase and not have the clipping."
Currently, the contractor that I am considering has said that either system would cost me essentiality the same. I can get a SolarEdge with the extra warranty, so on and so forth, and do it for the same price as the Enphase....
Does this seem out of the ordinary to you? (given the comments that Solaredge is less costly? I was originally thinking that the extra labor cost and warranty pretty much got me to the same place..... or could it be he gets incentives from Enphase if he sells that product?)Comment
entgegnen, responding to your points.
1. If you have the 25-year warranty and are comfortable relying on the company for the next 25-years to support that warranty, then getting the warranty on the SolarEdge inverter makes them equal. From what I've seen anecdotally of central inverters (not necessarily SolarEdge ones, since they're newer), they do fail sometime between 1 and 2 decades, and if the company isn't around to replace it, then you're on your own. With a non-SolarEdge inverter, this may not be so bad -- in 10-20 years it's likely that inverters will be even cheaper and more capable and you could install any brand. But with a SolarEdge inverter, you're dependent on either the company existing and supporting you, having access to a cold spare, or rewiring to remove the optimizers so you can use another brand of inverter.
Now I wouldn't necessarily let that stop me if I liked the SolarEdge for other reasons. But I'm generally pessimistic on young companies being around in 25 years, so I like options that leave me with flexible options down the road. Because who knows what the future holds?
2. Re StorEdge -- to me the modular AC battery just seems more practical. the StorEdge is yet another thing tied to your SolarEdge inverter -- more lock-in, more things all depending on a single device. While the AC battery is dependent on the Envoy-S Metered gateway (mostly so it knows optimal times to charge and discharge), it is not dependent on the microinverters in any way. In fact someone who doesn't even have solar panels could benefit from time shifting with the AC battery setup. One can also buy in small increments - like panels, at a certain point, the more dollars spent, the lower the return, as you're offsetting less and less electricity. 1.2 kwh or 2.4 kwh might be sufficient to get me through the rate peak -- I might not be able to capitalize on additional capacity. But these are so far off from practical today that it's of course hard to really say. But again, I like options and less upfront spend. Keep your money for later when you have more info on what you need, and prices and technology have improved even more.
3. Enphase's stock is certainly doing worse, but they seem sustainable to me. They're investing a lot in future products. They strike me as a company that may not do well on investor returns for a long time, but still make solid products and money to pay for ongoing development. SolarEdge is hot now, but Enphase was the hotness just a moment ago. Maybe SolarEdge will be huge, maybe they'll struggle. I don't know. I know that if Enphase goes out of business, I have low-cost options that don't require me to invest in advance or limit my future choices. I can wait and see.
5. Clipping -- what everyone is saying. Play with some PVWatts simulations and tweak the DC-to-AC ratio. It'll give you an idea of how much you're likely to lose from clipping. Good chance it won't be enough to buy a yearly movie ticket.
6. sensij makes a good point about the trunk cabling. Ultimately microinverters are just feeding back standard 240V AC. If you can get cabling adapters, anything else that outputs 240V AC should be able to play along. They may not be monitorable by the Envoy-S, but they shouldn't interfere with it either, and may have their own monitoring solution. Even if I choose not to go with more microinverters, I can always augment with a central inverter at that time, delaying my spending until I've actually have a need and the future options in front of me.
Were my combination of needs & priorities different, I could have easily ended up the SolarEdge. Clearly it's a good product. For me the biggest factors were really just preserving my wall space and having low-cost/low-commitment options should either my installer or the maker of my inverter disappear. Everything else contributes but that's what really tips the scale for me, and the situation will be different for other people. Also, in my case, the extended warranties for SolarEdge would have pushed the price higher than Enphase, and I really don't like buying extended warranties even when I'm 100% sure the company will be around to honor them (and I'll be in the house to benefit from it). Another case of going all-inclusive up front, or a la carte as you actually need it. Some folks will prefer one over the other. Just like some people are happier buying an oversized system relative to what they use right now vs saving on upfront costs.Last edited by ltbighorn; 06-16-2016, 06:02 PM.Comment
2) of course the AC battery does not give the option for backup power but the StorEdge does.
3) SolarEdge = profitable, Enphase = not profitable.
6) if they are on the same trunk they will interfere with communications. They would likely need to be on their own trunks to communicate, then to the same single AC disconnect.
Thanks again Ltbighorn. Those are compelling points.
Sensij - I think you have a solar edge system. Knowing everything you now know - from this forum and from your own experience - would you still have gone solar edge (back then)? Or asking a different question, based on how things developed since then, would you go Enphase today....?Comment
I love how much knowledge I've been able to extract from my system by looking at the optimizer data. Seeing how voltage and current respond to the changes in environmental conditions has provided some very good real-world data to support the theory, and I am not sure I would have been able to learn as much from any other system. I have some shading on the roof with a ridge immediately to the west (with some palm trees on top). For those reasons, I would still choose SolarEdge for that system if I had to go back and do it again.Thanks again Ltbighorn. Those are compelling points.
For my next system (I am moving soon), I expect to have less shade, and less interest in the granular data. Until I really dive into it I don't know for sure what I will do, but I suspect that an inverter like the Fronius Primo will be my first choice. It is the least expensive high quality grid-tie inverter that I know of.
I *might* consider spending extra to put in a bi-modal inverter to support peak shaving, since I intend to be in this house a long time and anticipate that eventually it will be cost-effective. Really though, that is probably the next inverter after the Primo fails. I like that a simple string design is more easily converted to a generic bi-modal system than either SolarEdge or a microinverter system would be; I'm not a big fan of the proprietary designs that seem to be a part of SolarEdge's business plan.
As i understand it, as battery systems are considered by the CPUC in the context of peak shaving, it is possible that approval for those systems will depend on showing that the battery charging is coming from a renewable source, not just charging from the grid at night and then discharging during the day. Still a lot of policy to be figured out there, but for that reason, I tend to like DC coupled storage systems more than AC coupled.
As for micro-inverters... while I respect anyone who weighs the pros and cons objectively and concludes that they are the right choice, I would not put them on my roof unless I could easily access each one in the event of a failure. Count me among those who thinks the optimizers should last significantly longer than the micros will, although the number of infant mortalities of optimizers that have been reported in the forum make me less sure of that than I once was.
CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
My reasons for getting 38 Enphase S280 inverters on my LG315 panels- I live near Enphase headquarters and know many of the engineers (indeed used to work with them) who are over there now; these guys are the best. So I trust the engineering and the company, plus would like to support a local business.
- From an engineering standpoint the micro solution is the best hands down as ltbighorn pointed out, reliability, distribution, etc. My installer (another local business been around for decades) says they've seen maybe one Enphase failure that was one of the first ones.
- Data is good and Enphase delivers the most of any solution. Temperature, voltage, current etc per panel over time.
- I have partial shading issues
- I wanted an expandable system (I first put in 22 panels, now am putting in a total of 38 and might go 42 eventually (max for three strings of S280's)
- I would like to try the Enphase battery later this year
- An AC coupled system is superior IMO
- I didn't want a big ugly inverter in my garage
I don't think enphase has earned the designation of "reliable" yet. The M190 was a disaster, and they have been very tight lipped about what went wrong and how they fixed it in the M215 and later. I would reserve judgement on reliability until they can prove they have a product that can last at least 5 years in the field.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
The M190 problems are well documented in this forum and elsewhere. Enphase started purging their own forum of discussion of it a couple years ago. They are reaching out to owners of the M190's to either replace them, or modify the firmware to allow less power. A mess.
More recent products have been better, but I don't think they have earned anything close to a reputation as reliable yet. -
A small sampling over on an EV forum (~4000 inverters with ~11000 device years) confirms some problems with the M190s, but almost zero with the M215s and M250s. Additionally, the M190 problems tended to be clustered on particular installs, suggesting either bad batches or site-specific issues. Both sets of products are relatively young and it's hard to say what the long-term (10+ year) reliability of any will be. The most info we really have is on how long central inverters tend to last.
Hey everyone-
1. I just want to say thanks for the debate/discussion. It has really helped me in deciding what to do. Over the last week, i've gone back and forth a few times.
2. I think at the end of the day, all three can be terrific options (string, optimizer, micro) depending on site survey, budget, usage needs, reliability, future adaptability, etc.
3. Two of the best comments I've received (on this and another thread) have been to (a) do a quick energy audit and see if I might benefit more cheaply from a few common sense economizing measures before jumping all in; (b) to understand that year over year there will be incremental improvements in the types of systems... but that the latest and greatest tech may not be the best value purchase $/watt... the more important thing is to jump on the train instead of always waiting for the "next" train.
4. So I've settled on an installer, a system, and a final cost. The installer didn't have the "lowest price" but was hands and away the most knowledgeable of the contractors I've spoken to and didn't steer me towards any one system over any other. (While not the lowest, the price was competitive-reasonable). I am also confident that he will be good to my roof. (And no sub contractors was a big plus). I've researched his contractor's license and I didn't find anything adverse.
5. I'll come back in a few weeks after everything is up and running to provide more details. But again, big thanks to Sensij, ButchDeal, and others who have shared their insight.Comment
A wise move, best done before system sizing. Before signing a contract is still good, if a bit late. Along with/after that, I'd suggest considering a look at the benefit/impact of possibly resizing the system (downward) based on the results from any conservation measures actually incorporated as a result of the audit.
While I certainly see this point, I had a different perspective. My goals are not exactly in-line with the utility or in-line with the (economize first, then go solar approach)... I want to approximate my system "output" with my usage at the median life of the system. Assuming a 25 year system life, and a certain fractional percentage of panel degradation year over year, if my system outputs 90-93% at year 12.5... I want to be in the position of NOT buying 7-10% of my electric needs from the utility (at that time in 12.5 years). So, within certain parameters, I'm more in favor of pushing the limit of what the utility will permit today... and creating a rolling buffer through things like incandescent - LED bulb change out... Air Conditioner upgrades, etc... so as system output slowly recedes, the shortfall will be addressed through such "simpler" upgrades... so that I have the largest overall period of not buying from the utility....
Certainly the economize first, then get solar to meet 100% of your needs is a reasonable one, and has the advantage of being able to say, if your system is not outputting enough, just add a few panels later... I didn't want the incremental add on of parts/labor... especially when retrospectively, adding the extra capacity (or planning out the more optimum capacity today) is a more efficient use of money long-term (just my perspective).
And all environmentalism aside, this is all about the Benjamins.Comment
Hello All,
I am a newbie to this forum and need the help of great contributing members here. I have been so amazed by all the technical knowledge and deep research by each and everyone of you.
I have no clue on engineering and technicals of a system. My research thus far has concluded that:
1) I want an efficient system given my limited roof space. So I have narrowed down to SunPower 335 and 345 and LG 320s.
2) I have shading so going with microinverters
3) reliability and warranty are very important as if something breaks, I have no idea how to fix
I was just about to pull the trigger but then started reading more and realized the type of inverter, the size of inverter, the brand, the brackish system, etc are all very important as well. So now I am completely lost on how to evaulate. I got the following three proposals. Can you all smart people help me decide which is the most reliable system and if the proposed accessories are sufficient and any good (what size inverters do I need)? Thanks in advance.
Proposal #1
24 LG320W with Tigo Optimizers (maximizers) – 7.68kW system.
ABB PowerOne 7kW inverter to allow for system size increases if needed (upsized inverter at no extra cost)
QuickMount premium flushing solution
Monitoring hardware and software included. Tigo system
Proposal #2 - I think SunPower inverters were embedded into each panel. Why do I need an ABB PowerOne inverter?
23 SunPower SPWR335W with Tigo Optimizers (maximizers) – 7.71kW system.
ABB PowerOne 7kW inverter to allow for system size increases if needed (upsized inverter at no extra cosT)
Monitoring hardware and software included- Tigo monitoring
Proposal #3 - I assume the monitoring system is included even though it is not stated? SunPower has its own monitoring system. Does it automatically come with the panel purchase or is it something I have to pay extra for?
7.94 kW (DC), 6.90 kW (AC) SunPower System 23 x SunPower AC Module; X21-345-C-AC
InvisiMount Mounting System
13 x Factory-integrated Microinverter
4 x Factory-integrated microinverter
Thank you for your generous help!Comment
Hi Versailles79-
1. Nothing wrong with adding your question to this thread - but if you created your own thread, you may get more feedback.... just an open ended suggestion for you. (I've found that as threads carry on.... the number of different people viewing drops off to only those few that are talking back and forth).
2. It appears you have limited roof space. Do you also have a limited budget? I've got a number of children, so $1000 bucks saved on my project is $1000 in their college fund, 2-3 trips to Costco, etc. I only say this because of your mention of SunPower. I did engage with SunPower. They were going to cost me about 70-cents per watt more. And drive back my "break-even/pay-off" a few years. Since electricity is electricity... and a utility company is a utility company... i could not justify the premium to myself. (It isn't like you can make the "premium gasoline" arguments.)
3. While SunPower appears to have very nice and cutting edge products... I was personally bothered about "heat" transference. Now I am not an engineer of any sort. But since SunPower integrates the micro converter into the panel, it seemed that there would be a likelihood of heat transference from the already "cook a fried egg" panel heat. At least with the Enphase approach, there is an "air gap" between the panel and the microconverter to disallow heat transference. (how many times have you boiled water on the stove and found that the pot handle got hot as well?) But if the pot handle isn't actually touching the boiling pot of water... it doesn't get hot. Perhaps this is an erroneous comparison.... but it was one I made.
4. If space is limited, you may want to look at the new Panasonic 330w panels (Panasonic HIDs). If you could do that set up for less than SunPower... you may want to think about it....?
5. I am not a big fan of subcontractors. If the person you use will ultimately bid out the labor... well, when did you get a chance to meet them? On installation day? Too late. I like to know who I am dealing with in advance. I look up their license numbers. I see if anyone has filed against their contractor bond or filed complaints. Hard to do if you don't know up front.
6. I found myself gravitating towards bids with good size local companies, but with not too much corporate bureaucracy. Unfortunately, I had a sad experience with a major brand. I called a call center to book an appointment - with essentially a sales man. Then the salesman "no showed" having not been made aware of the appointment from the call center. Then when he called to reschedule, he no-showed on his reschedule! Then he emailed an apology and offered a gift card. I emailed him back, accepted his apology, and said "lets cut to the chase." Can you offer me a system below a certain price per watt? (based upon the 9 quotes I had received from one of the auto-solar-marketplace websites). I never heard from him again. I guess there just wasn't enough ignorance or profit in dealing with me... such is life.
So look at your systems above. What is your cost per watt? Assuming al things equal (quality of equipment, quality of installation, confidence in the guys going up on your roof and not messing everything up - or leaving you with a leaky roof - are you willing to pay more for an electron traveling across the grid from one quote than another?
Good Luck!
Great reasoning and agree with the points although I ended up with a sunnyboy with the sps. Same points just different weights.I was debating the same decisions (along with string inverter). For my size array, all options were pretty much a wash cost wise. The reason I ultimately went with the Enphase microinverters:
1. Space is at a premium here in SF, and I didn't want the inverter taking up space in my garage (particularly since it's deeper than anything else I have wall mounted, and thus cuts down on walkable space). Outside isn't a better option as it's a narrow access path to the neighbor's front door, and also very visible from the street (neighbors would be very irritated).
2. Having the inverters within 10 feet of the array removes the need for the external cut-off switch in my area, I believe, so one less box on the exterior wall (especially with all the big red labels now).
3. I personally prefer the safety situation of running AC from the roof rather than DC. Not a big deal though.
4. I can expand without having to make decisions today about how much excess inverter capacity to purchase.
5. Doesn't lock me into SolarEdge -- I haven't pre-purchased extra central inverter capacity that only works with SolarEdge optimizers. With Enphase microinverters, if there's a better product out there in 5 years or whenever I want to add, I can use it without discarding excess pre-purchased capacity. I can feed additional AC on one of the existing branches without modifying or interfering with the Enphase setup.
6. 25-year warranty and expected lifetime is longer than central inverters.
7. I build redundant/reliable systems for a living, and I work very hard to avoid single points of failure. A central inverter is a giant single point of failure. Microinverters are lots of points of partial failure. Optimizers are single point of failure + lots of points of partial failures, worst of both worlds. It just doesn't sit well with me. I realize that the failure rate of the optimizers is likely to be much lower, but there's still the inverter. It may be a wash, but psychologically I'm more comfortable with multiple points of partial failure, given the next two items. Similarly I build arrays of systems, servers, devices, etc. with the expectation that some will fail, but the system as a whole keeps on chugging.
8. With microinverters, the incremental cost to do replacements or maintain spares out-of-warranty is low. With a 25 year warranty, I'm already ahead, but should Enphase go out of business, I can pickup spare micros on ebay quite cheaply. Even if there are failures, I think it unlikely that all the micros would fail early. In the unlikely situation SolarEdge goes out of business (or no longer makes a compatible product), because of the higher cost to keep cold spare inverters, I'm less likely to have one on hand, or have more capital tied up in them. If optimizers fail too, then I'm in a nasty lock-in cycle of having to keep buying more of what's not serving me well, because more money is sunk into replacements that only work with more SolarEdge stuff.
9. My roof is flat and only requires me to climb a 1-story ladder. My panels are being installed in separate rows with a good tilt. Should my installer not be around to honor their 15-year workmanship guarantee, I'm confident that I could do replacements myself without risking life and limb. I can get up there easily in 10 minutes.
10. Allows me to combine house consumption monitoring (Envoy-S Metered) and integrated that into the same dashboard overview as my production data.
11. I can take advantage of the Enphase AC battery should it become cost effective. I feel like Enphase's approach/product is more likely to bear fruit for my approach than Tesla's.
When comparing for yourself, to keep it apples-to-apples, make sure to include the $250 fee for Enlighten Manager access needed for per panel monitoring.
I'm by no means advocating that any particular option is "THE BEST", just sharing what influenced my decision. Hope it helps.
EDIT: I should also add, I live in cool sometimes foggy climate, where no one has AC. So with good ventilation on the tilts, I think the microinverter reliability can only benefit from the milder conditions vs say, someone in Phoenix AZ.
Very cool.Comment
Sunpower's approach to installing microinverters is no different than Enphase's. Neither is more integrated than the other. Your comparison here is erroneous.3. While SunPower appears to have very nice and cutting edge products... I was personally bothered about "heat" transference. Now I am not an engineer of any sort. But since SunPower integrates the micro converter into the panel, it seemed that there would be a likelihood of heat transference from the already "cook a fried egg" panel heat. At least with the Enphase approach, there is an "air gap" between the panel and the microconverter to disallow heat transference. (how many times have you boiled water on the stove and found that the pot handle got hot as well?) But if the pot handle isn't actually touching the boiling pot of water... it doesn't get hot. Perhaps this is an erroneous comparison.... but it was one I made.
I bet you didn't meet the person actually working on your roof until the day of the install. The slick sales guy or even the company owner is rarely the one who actually does the work, sub-contracting or not.5. I am not a big fan of subcontractors. If the person you use will ultimately bid out the labor... well, when did you get a chance to meet them? On installation day? Too late. I like to know who I am dealing with in advance. I look up their license numbers. I see if anyone has filed against their contractor bond or filed complaints. Hard to do if you don't know up front.
Also, a plan in which you size the PV system to cover 100% of consumption is often not the most cost-effective choice, for those who seek to maximize their benjamins. No one knows what the tariffs will be 12.5 years from now, or where you will be living. At least in southern CA, today and for the next few years, leaving a small amount to be paid to the power company may be more optimal.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
I must admit I considered this a small but non-zero influence as well. When a US and in particular local manufacturer makes a quality, competitive product, I like to support it. That said I went with LG panels, though SolarWorld/Suniva were my secondary choices/quotes, even though neither is local.My reasons for getting 38 Enphase S280 inverters on my LG315 panels- I live near Enphase headquarters and know many of the engineers (indeed used to work with them) who are over there now; these guys are the best. So I trust the engineering and the company, plus would like to support a local business.
Originally posted by entgegnan2. I think at the end of the day, all three can be terrific options (string, optimizer, micro) depending on site survey, budget, usage needs, reliability, future adaptability, etc.
Absolutely and I agree that they're all excellent options, it really does come down to your specific preferences and situations.
Energy audit is definitely a good idea. The cheapest energy is the energy not purchased..
Originally posted by entgegnan4. So I've settled on an installer, a system, and a final cost. The installer didn't have the "lowest price" but was hands and away the most knowledgeable of the contractors I've spoken to and didn't steer me towards any one system over any other. (While not the lowest, the price was competitive-reasonable). I am also confident that he will be good to my roof. (And no sub contractors was a big plus). I've researched his contractor's license and I didn't find anything adverse. 5. I'll come back in a few weeks after everything is up and running to provide more details. But again, big thanks to Sensij, ButchDeal, and others who have shared their insight.
Sounds like a good move - best price you can get from an installer you trust to do high quality work. No need to hold off on the details though, I don't think anybody's feelings are going to be hurt regardless of your choices.
I feel similarly about sub-contractors, but for different reasons. To me it's not so much about meeting them, but rather each layer of bureaucracy slows communication and response, which allows more chances for mistakes or subpar work to creep in. The installer you contract with may have a solid reputation for making things right, but I'd rather see things done as best as possible the first time, as sometimes mistakes aren't discovered for some time, and each time I have to deal with an issue again (and the complexity of that resolution) takes away from my life enjoyment. It's part of why I'm paying a small premium to have my roofer (in business for 35+ years) doing all the penetration sealing and guarantees.
Originally posted by entgegnanWhile I certainly see this point, I had a different perspective. My goals are not exactly in-line with the utility or in-line with the (economize first, then go solar approach)... I want to approximate my system "output" with my usage at the median life of the system. Assuming a 25 year system life, and a certain fractional percentage of panel degradation year over year, if my system outputs 90-93% at year 12.5... I want to be in the position of NOT buying 7-10% of my electric needs from the utility (at that time in 12.5 years).
...And all environmentalism aside, this is all about the Benjamins.
These two statements are somewhat at odds. Overproducing today so that you're completely offsetting in 12.5 years will probably produce a worse financial return than simply buying a small amount of utility power down the road. If you just want it for environmental or psychological reasons, fair enough, but if the goal is to save the most money, then buying a system that meets your needs today, but requires you to buy some kWh down the road, is probably more cost effective. Obviously it depends on the details, but typically purchasing small amounts of power from the grid is not terribly expensive. Moreover, many utilities do or will require certain minimum fees, so the optimal production may actually be for a less than 100% bill offset, since they literally won't let you zero out your bill.
Indeed. People can truly see all the same considerations and come to a different conclusion about what's best for them, and that's great. Lots of good options out there.Originally posted by nomadhGreat reasoning and agree with the points although I ended up with a sunnyboy with the sps. Same points just different weights.
Very cool.
