Most Popular Topics
Questions to ask installer
Ya, goto PVwatts and find out what the yield rate is for your area and compare it to the sales person's number then ask them how they can justify such high projections. Most outfits fudge these numbers in order to make the system look more cost effective. Your particular locality will produce (quite closely) a certain number of effective full hours of solar production. In my area you get about 1650 hours - so a 10kW system will produce 16,500kWh of energy each year.BSEE, R11, NABCEP, Chevy BoltEV, >3000kW installedComment
For the OP, a rule of thumb in New Jersey is about 1200 kWh annually per kW of panels. Though that's probably a little conservative if you have a southern facing roof without much shade. So based on this rule a 10 kW system produces about 12,000 kWh per year. But you should check pvwatts for your specific situation.Comment
How do I know which solar panel s and micro inverters, or single inverter, are best?
Which solar panels will perform best, have the least degradation of service, and will not need to be replaced for at least 25 years: Suniva OPT-285-60-4-1B0, LG 315, or SolarWorld SW 285 (or 290) Mono?
Also, there seems to be a differing of opinion amongst solar companies. Most swear that the best way to go is by using Enphase Micro Inverters. A few say that those fail very often and are "crap".So which is best: Enphase Micro Inverters or (1)*SolarEdge w/Optimizers Mod. SE5000 (or Mod. SE6000) 240V? By the way, who pays for labor when an installed solar system part fails?
Do both inverter systems work the same? It's not like the old Christmas Lights is it, where if one bulb went out, they all go out:in my case if one panel goes down......?
Thank you.Comment
Also if in future 300W is upgraded to 380W panel, then having P400 beforehand might be good ?Comment
Why do you think a P400 is not appropriate for a 60 cell module ? Won't it dissipate heat better against a 300W panel as opposed to using P320? Isn't oversizing the optimizer better?
oversizing is not better. Right sizing is.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
My installer ended up using the P400 for my 310 watt panels. I did call solaredge to confirm that it would be fine and the guy I spoke to said it was no issue at all using the P400 with a 60 cell panel. I don't think it's any better but it doesn't appear to be worse.Comment
They will work with some 60 cell modules but they have different ranges. The P400 is geared to much higher voltages and lower amperages. in the moderate performance like 310w 60 cell not an issue, in higher performance 60 cell, it is getting outside the range.
There appear to be some installers that are just using P400s with all residential to be lazy, seems odd to me as it is not that hard to choose when to use the P400 (got more than 60 cells? yes. use the P400).
For example the SolarWorld SW300M has a short circuit current of 10.23, the P400 is only rated for 10.1 but the P320 is rated for 11. use the SW300M with a P400 and void the warranty on the P400 but fine with the P320Last edited by ButchDeal; 06-08-2016, 12:49 PM.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
The good news is that the short circuit current at STC is 10.1 amps so I should be just ok with the P400.Comment
I hear what you're saying. I'm not sure why they use the P400s. Perhaps they have a bunch of them. My sales guy mentioned something about the P400 having a much higher max voltage and it can get quite cold where I am which increases voltage. However, I have the Winaico 310 watt panels and they have open circuit voltage of 40.3 (not sure if that's the right measurement). Considering the temperature coefficient of 0.29%/C, it would have to get 60 degrees colder than STC so it would have to be -35 degrees celsius to get a voltage of 48. Considering the record low in NJ is -37 celsius, I'm probably ok with the P320.
Well you have to look at all the limits. the voltage one is not that important here as you are well inside it.
but your Winaico 310 modules have a Short circuit current of 10.1 amp which is the limit for the P400. The P300 has a shortcircuit current of 10amp so not good there, but the P320 has a short circuit of 11amps...
