  • dust999
    • 31
    Fun output comparison (SolarWorld + SolarEdge) vs (Canadian Solar + Enphase)
    My solar system has been up and running since November last year and I've been comparing the output of my system to another install 6 miles from my house. I'm running SolarWorld + SolarEdge, the other install is Canadian Solar + EnPhase. The two systems are virtually identical in terms of rated output. Both sites have no shading issues other than snow coverage effects in winter.
    The Canadian Solar system has produced, on average, 6% more year to date than my SolarWorld system. It's a fun/un-scientific comparison, we are 6 miles apart so the weather variables influencing output are somewhat different, but it would suggest that the CS + EnPhase combination produces more than my SW + SE combination. = potential buyers remorse on my side....
    My specs:
    31 x 280W SolarWorld Black Mono
    1 x SolarEdge 7600 inverter
    31 x P300 SolarEdge optimizers
    Output = 8,680W
    Azimuth = 154
    "Competition" specs:
    The info I'm getting for this install is off the public EnPhase portal which does not show all the specs.
    34 x CS6P-255P Canadian Solar
    34 x EnPhase micro inverters, unknown model
    Output = 8670W
    Azimuth = 167
    • 3802
    My specs:
    Output = 8,680W
    Azimuth = 154
    Output = 8670W
    Azimuth = 167
    The enphase one is closer to south facing than yours ( 13 degrees).
    Are there any shadows on the two sites?
    Also your nomenclature of rated output is inaccurate, that is the rated STC DC size of the system, not the rated output.
      • 15038
      Fun yes, conclusive, probably not so much.
      Too many variables can influence estimated output to be able to call a 6% difference significant, starting with the accuracy, and the differences in the accuracy, of the recording/reporting equipment.
      Anyway, 6% is not that much of a difference. BTW, What's the tilt of the two arrays. That will influence output some as well, more so in winter. Also, what does PV Watts give as an estimate for each system for the period Nov - April ?
      • dust999
        • 31
        Sites are shadow free other than snow accumulation.
        • randomuser
          • Feb 2016
          • 83
          How granular is PV Watts? I just entered my current address and the address of my former residence. Google maps driving directions says it's 6.8 miles between the 2 houses, so I'm guessing it's about 6 miles as a bird flies? I used the same parameters for both addresses and PV Watts shows the same electricity generation output.
            • 3802
            does the location 6 miles away have some indication that it should have DIFFERENT generation? is it maybe 6 miles vertical away?
            It is possible for there to be a generation difference in such short distances but PVWatts uses TMY data for weather, and it just doesn't have that resolution.
            Also PVWatts does not take into account local geography, like proximity to mountains...
            Most differences are due to location specifics like tilt, azimuth, shadows, followed by equipment differences (including measuring equipment).
            • dust999
              • 31
              My inverter is the revenue grade model used for SREC reporting. No idea on the EnPhase setup.
              Do not have the tilt angles.
              PV Watts:
              PV Watts 154 angle PV Watts 167 angle
              Jan-16 706 731 4%
              Feb-16 842 869 3%
              Mar-16 1,094 1112 2%
              So, the difference in azimuth already accounts for a chunk of my 6%...........................
                The point to using PVWatts is not necessarily for location... as you see, the granularity is limited. If you use the SolarAnywhere option, I think the boxes may be something like 10 km x 10 km, about 6 mi x 6 mi, but I'd need to look closer to be sure. What PVWatts *will* clearly tell you is the effect of the different array orientations on expected output, with both azimuth and tilt contributing strongly enough to possibly explain the 6% difference (or more).
                  • 3802
                  ok so you have a 13degree difference in azimuth as self reported, (possibly more as there is a potential for ~5 degree difference there as well)
                  unknown pitch differences.
                  and you are concerned about a 6% difference in output?
                  The azimuth is most of that difference
                  Tilt is likely the rest.
                  not to mention the differences in solarworld vs canadian (canadian poly modules have highest diffuse light rating, so cloudy days they should slightly out perform) Solarworld black modules will slightly underperform on hot days due to added heat...
                  These differences would be tiny compared to the azimuth difference though.
                    • 3802
                    PV Watts:
                    Jan-16 706 731 4%
                    Feb-16 842 869 3%
                    you will need the tilt or at least a decent estimate of that. The bigger the tilt the more the azimuth will impact
                    as well as the tilt is likely not the same on the two structures causing its own variance
                    So the revenue grade meter in your solaredge has 0.5% accuracey
                      • 15038
                      PV Watts:
                      Jan-16 706 731 4%
                      Feb-16 842 869 3%
                      I suspect the unknown tilt may be a fair portion of the difference from the change in output diff. per month. Also, note that the PVWatts 3 month estimated totals show about a 2-3 % diff. Throw in Nov. & Dec. w/ their likely (?) 3-4 % diff. and the Nov- March diff. in az. output will go up some as well.
                      The PVWatts azimuth diff. looks like about half the total observed diff. Trying to find/explain the other 3 % is separating fly specks from pepper, particularly given the rest of the unknowns/uncertainties. You'll be lost in the noise.
                      • DanKegel
                        • 2093
                        To the OP: if you like informal competition, you may enjoy pvoutput.org. Check it out. It's pretty easy to set up automatic uploading from most monitoring systems.
                        • dust999
                          • 31
                          Thx, I'll take a look at it.
