What governs a solar panel's current flow output besides load? for example my panel is rated to put out 5 amps. Never have I seen it reach that peak with loads. Max I have seen with loads are 3a (seems like its struggling) I have tried completely dead batteries, full batteries both with and without controller, even plugged my necked sister (for tanning purposes. . not really but . . . .
) The only times I've seen the amp meter reach 5amps while connected in full sun is when a battery charger was doing its job. Open circuit full sun the panel puts out something close to 3.8 There is some damage as the glass is spidered but not too many shadows. I need to know for factoid reasons. (cuz this @#$* is bugging mah)
Panel stats: 180w @5.4a /72 cell
open circuit output: 37-40v @ 3.8a Load output: 14.4v @ 2 - 2.8a max amp)
So my questions are:
1) WHAT DETERMINES CURRENT FLOW/OUTPUT IN FULL SUN BESIDES LOAD RESISTANCE. (shade, ambient light, amount of light, and my sister have already been considered)
2) Can there be a shortage, broken cell or broken connection causing the short fall in amps? (one cell heats up much hotter (cant touch it) than area cells. Direct sun beam va mirror on this and surrounding cells makes the current increase .8 - 1.2 amp. Direct pressure on this cell will cause complete loss of current)
3) With out direct sun light, how many amps can one expect a panel to put out (ex: 5 amp mono in average day light no sun) What % of rated amps can I expect?
Thanks all. The correct responder will win the satisfaction of helping a person live happily-ever-after (fixing this @#$%& problem
) Making this world a better place . . one solar panel owner at a time
