I think its time to add a back up to get me through the winter months, my needs are to maintain the health of the batteries through out winter, so as per my other post my specs at the moment are:
160watts solar panel and 2x75 amp batts.
I was thinking to add a 50W Telescopic Vertical Axis Wind Turbine, as above its role will be say like a trickle charger during winter:
pic:
I was thinking to connect it to the plus on one of the batts and the neg on the other is this correct, and is there any reason wind and solar can't be connected.
Voltage output: DC 12-16V
Current output: 4A maximum
Edit added some info from the site:
There is no need to use a charge controller when charging the battery. The battery can be connected directly to the battery terminal of the Wind generator for charging. When the battery is fully charged, the generator will automatically cut off the power to battery and the display will go out.
Thanks.
pic:
Thanks.
