I am completely new to the subject and looking forward to receive your advice. I just want to understand the terminologies, and then hopefully I will be able to combine my kits.
I have a 500W inverter rated power is 0.5 KW, MPPT Range (VDC) is 46-75. My solar panel is 95 W,
Maximum System Voltage is 750 V, Open Circuit Voltage is 22.1V and Maximum Power Voltage (MPV) is 17.9 V. Is this panel compatible with the inverter? Does the inverter MPPT range means that the solar panel or solar panel array must produce voltage between 46 and 75?
Thank you for your help in advance.
