Cleaning Solar Panels.
I am thinking about getting a pressure water so that I can get the water up to the second story roof, and make it 'rain.' Hopefully that will be enough to clean the panels.Comment
My installer said to used Simple Green. My friend's installer said use water only. I don't know who's right.Comment
Most of solar PV is not rocket science. Cleaning panels is probably a lot like cleaning a launch pad - doesn't matter much the method as long as it's done on a somewhat regular basis with safety in mind. Just don't do it when the panels are hot and don't use a pressure washer. Shortly after sunup is perhaps best.Comment
After going to both Home Depot and Lowes to look at the options, I choose this squeegee product.
The plan is to just spray the panels and then squeegee them off so as to not get water spots.
I also went with a 16 foot extension product from Lowes. All the good extension poles have threads on the end.
The squeegee I selected wasn't meant for a threaded pole, so I had to place it on the top of the pole a screw that sucker down.
To avoid potential water spots from hard water, instead of a squeegee, how about a leaf blower to blow the water droplets off? I know, hard to operate from the ground when panels are on the second story roof, but how about for ground mount panels?SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Ah, the old Air Knife trick... remember roll through car washes, and the 70mph dryer blowers ?Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I will only hose from edge of roof. If your house is 2 story high, avoid walking on top of your roof so you wont have to worry about breaking the tile or falling off
PS. You probably get excite to clean your panels the first 2 years, after that who knows.Comment
The idea of using Rainex on PV panels comes up about 1X/yr or so. As I recall, in the most recent iteration, one of the moderators contacted Rainex and they seemed reluctant to say it was OK, based on lack of information or testing.
A couple of things to think about, among other things: What might be Rainex's possibly deleterious effects on the transmission/reflection/absorbance properties with respect to spectrum wavelengths important for PV ? Also, what effects might Rainex have on any anti reflection coatings or treatments applied to the surface of a solar panel ?
Also, to the degree that warranties mean much of anything, I suppose added to that might be considerations as to what effect such a treatment might have with respect to panel warranties.
FWIW, I can't seem to measure a difference in the performance of a clean array whether it has water spots on it or not. I don't know if that's because water spots have higher transmission characteristics for wavelengths important for PV production than my eye would lead me to believe, or the effect is too small to measure, or my instruments and methods can't differentiate a difference that small, or my measurement techniques suck, or all of the above and/or more. But, if I consistently cannot measure a difference in performance between a clean and unspotted array, and a clean spotted array, I believe it's safe to conclude that until I see or do something that leads me to change my mind, hard water spots don't affect my array's performance enough to warrant any extraordinary efforts to get rid of spots caused by minerals in the water.
As usual, take what you want of the above. Scrap the rest.Comment
I don't worry about cleaning my panels. I live in probably one of the driest and dustiest places around (Phoenix AZ. USA annual rainfall 6"-7"). I've yet to see anything on the panels that makes me feel like I have to get out a ladder and hose and then walk back and forth across my cement tile roof. I let the rain do the work and don't worry about a few percent solar loss compared to the damage I could cause my panels, my roof or myself. If I lived where there was heavy snow I would probably clear the panels (but I don't).Dave W. Gilbert AZ
6.63kW grid-tie ownerComment
Problem is, the panels are so dirty because of the rain.
