LG is definitely a premium brand compared to solar world or Canadian solar. On paper it has slightly better performance numbers and supposedly has better quality. To compare real life performance, it might be best to look at your neighbors' performance on pvoutput.org. For example in San Diego, http://pvoutput.org/listteam.jsp?tid=859. If you go back to May to August numbers (best production months), you will see LG based systems consistently ranked at the top of the efficiency charts, although the benefit can be subjective, as the difference is often less than the 7-8% premium in cost increase. So the choice is very much personal. It all depends what's important to you. Based on pvoutput.org, locally I see way more LG systems than any other brand. If you think people who can manage and care enough to link their system to pvoutput.org is at least technically savvy statistically, their collective vote of confidence (with their money) must mean something.
Most Popular Topics
Are the LG 305w worth an extra $0.30/watt than Solar world 280w?
LG is definitely a premium brand compared to solar world or Canadian solar. On paper it has slightly better performance numbers and supposedly has better quality. To compare real life performance, it might be best to look at your neighbors' performance on pvoutput.org. For example in San Diego, http://pvoutput.org/listteam.jsp?tid=859. If you go back to May to August numbers (best production months), you will see LG based systems consistently ranked at the top of the efficiency charts, although the benefit can be subjective, as the difference is often less than the 7-8% premium in cost increase. So the choice is very much personal. It all depends what's important to you. Based on pvoutput.org, locally I see way more LG systems than any other brand. If you think people who can manage and care enough to link their system to pvoutput.org is at least technically savvy statistically, their collective vote of confidence (with their money) must mean something.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
This is BS. There is no evidence of anything special about the performance of LG panels, except that they do offer higher area efficiency for those who want to minimize the number of panels installed. The top performing systems in PVOutput's Team San Diego in May though August were those systems with optimal panel orientation, installed in locations with good weather... there isn't any more to it than that. Some LG systems met those criteria, but so did systems from other vendors.16xLG300N1C+SE6000[url]http://tiny.cc/ojmxyx[/url]Comment
Example: Sensij's system slightly out produces mine by about 2%, +/- a bit, on a daily kWh/STC Watt basis, in a fairly consistent way even though we're about 20 or so miles apart. He's using Canadian Solar, I've got Sunpower. I probably have slightly higher daily irradiance by some fraction of a % (note to Sensij: Hurry up on the Davis), but I've got a slight loss due to late afternoon shading of ~ 1-3% depending on season. Our orientations are similar. The diff. due to those factors, while seeming consistent, is probably too small to a ascribe to any one factor. Note S.P. vs. C.S.
If performance for most quality products in terms of annual output under similar conditions is nominally the same, that would seem to cease being a figure of merit. Other factors then move up on the importance scale when determining cost effectiveness.
In a bigger sense, this all comes back to most bang for the buck.
Since, at his time anyway, panels don't seem to be failing much, a product warranty isn't much use as a criterion, and performance warranties are, even with almost impossibly detailed monitoring, about useless because they are essentially unverifiable and therefore meaningless. That leaves things like appearance and IMO, the most important - the vendor/installer quality and reputation as one of the big arbiter of price. The extra few bucks paid to a quality vendor will be quickly forgotten. The poor quality risk from "Larry with a ladder" type vendors is greater than from established quality vendors. Such poor quality will be as visible as a boil on a nose and will never heal or leave.
Since most of the cost of residential solar is a first (installed) cost, the goal is to figure out/decide how to translate first cost into most long term bang for the buck.
Low initial cost and lowest long term cost (or max. long term savings) using life cycle costing, LOCE or other methods of costing/process economics are not the same.
Do the homework - know what's available and possible. Learn how you're charged for electricity and how that may change. Determine your loads and goals. Determine suitable equipment for your needs. Choose you vendor wisely. Negotiate tough but fair without squeezing the vendor so hard they feel forced to skimp on quality in ways you'll never know. Get your roof inspected/serviced.
Take what you want of the above. Scrap the rest.Comment
Ok, before calling someone else BS, maybe you can offer some counter evidence first. At least I presented some real evidence and statistics to backup my logic. How about you take ANY period including now and on clear days (so orientation and location can't be a factor), I can bet that you will find more LGs in the top 10 than any other brand (maybe combined). BTW, I do think CS and solar world are a decent brands for the price, but you do get what you pay for.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
One thing I don't see discussed here is the impact of more efficient panels on balance of system (BOS) costs. It seems reasonable as a first approximation to assume BOS costs are proportional to number of panels installed. If this is true, then a 10% increase in panel efficiency will reduce BOS costs per watt by 10%. So in many situations I can believe a 30c/watt premium for more efficient panels is more or less returned in BOS savings.Comment
Also a $0.30/w increase in module costs is more than 30% increase in module costs. Modules are the most expensive part of the materials so a 30% increase in modules comes to more money than a 30% decrease in BOS.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
That really depends on if you are including labor costs in BOS. With labor included, BOS costs are going to be higher than modules costs in many situations.Comment
But even the labor is not going to go down that much. One module or even two modules less is very slight less labor.
We pay contractors on a $/w basis like most other large installers using local contractors.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
hey guys, i was able to negotiate the price down to 3.60/w on the LG panels. So now there's only a 20 cents difference. HOWEVER, something I never thought about before was the use of Solar Edge vs Enphase.
Solar edge performance is slightly better from what I saw which would potentially allow me to maximize the 300w panels but the 10 year warranty is making me shy away. I do have the option to use Enphase... what to do... what to do....Comment
That's interesting. So you would pay 20% more to a contractor to install a standard size 300 W panel vs a standard size 250 W panel, even though the work involved is identical? Did I understand that right?Comment
Solar edge performance is slightly better from what I saw which would potentially allow me to maximize the 300w panels but the 10 year warranty is making me shy away. I do have the option to use Enphase... what to do... what to do....The key for life is to make you happy ... If you happy to have LG panel, you should not be shy. I like is to have American Made panels as I am American ... So I choose SolarWorld. I will choose SunPower if I could get better deal at that time. I do not want to use Chinese stuffs.
I choose enphase over solaredge. It is for the 25 years warranty and I like to buy from someone who learn their failure and fix their mistake vs someone is new and never taste a failure. It is the way I learn. Solaredge has some claims for the advance on their optimizer. However, there is not much time for them to prove.... 10 years later you can see the different, but not now. Everything now is just talk ...
If you like Solar Edge, buy additional warranty up to 25 year, you will get what you need.
10 years later, we will compare noteComment
well we don't pay by the module just like everyone else we pay by the watt. so we would pay the same for installer to install a 10kw system regardless of the number of modules. Most of the work is NOT in putting the modules on the roof. One less module makes very little difference. There are thousands of other things that will change the amount of work regardless of the size or number of modules.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
what 10 year warranty? SolarEdge inverters come with a 12 year warranty that is extendable to 20 or 25 years at slight added cost.
http://www.solaredge.us/groups/us/service/warrantyComment
