Most Popular Topics
What is next after NEM?
Yes, I got the Rainforest Eagle from Amazon. I think it was right at $100 for it. PG&E customers log on to their account, then go in and activate the 2nd radio channel on the Smart Meter to get the meter data. This data can either be read locally from your router or through Rainforest's web servers. You can also set up an account with wattwise since PVOoutput will take the wattwise data and plug it into your account.Comment
You have enphase, so I do t know how to get voltage. With solaredge, it is a tab next to where you set temperature. Try looking there.Comment
Btw, nice display.
From PVOutput, go to favorites, search for JPL test. He is near you and has the same size system. You can compare his output to yours to verify yours is working as you think it should.Comment
I see. I could get voltage from Enlighten, but not on PVOutput. I do not see the tab in PVOutput for it
I am not sure how to add it ... Like to get thing completed.
Voltage is not included in the Enlighten API. If you'd like to manually upload the voltage data to intra-day records that already exist, PVOutput supports that. Check out the live loader. It is easy to use, once you get the hang of it.
CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
