My Solar panel system is completely off grid. The inverter I chose is a 24vdc with an modified sine wave output. The system operates all my power tools and even my stereo amplifier. I was looking to use a solid state electric fence charger which is AC powered. I called the manufacturer, Zareba. The only response the rep could give me is to plug it into a standard outlet. Does anyone have experience running fence chargers on modified sine wave inverters?
Solar Inverters with electronics
Try it and see if the unit heats up. A little warm is OK. really toasty hot is bad and you need pure sine for that device. Sorry.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
There are fencers that run directly from batteries. Some are more efficient than others. I would find oneMy Solar panel system is completely off grid. The inverter I chose is a 24vdc with an modified sine wave output. The system operates all my power tools and even my stereo amplifier. I was looking to use a solid state electric fence charger which is AC powered. I called the manufacturer, Zareba. The only response the rep could give me is to plug it into a standard outlet. Does anyone have experience running fence chargers on modified sine wave inverters?
and use a rather small DC-DC converter to run it. Since the fencer may draw power in bursts, a super
cap at its input terminals might allow a much smaller converter running continuously, instead of a large
one capable of the surges, and idling at 0% efficiency between. Bruce RoeComment
It seams to work.
I don't want to get a battery operated since I have my whole solar panel - battery storage - inverter working and supplying power to my outbuilding. All the DC units I saw required a 12 or 6 volt battery. My unit is 24volt and so not convenient to use a subset of my batteries. I purchased the AC unit and plugged it in. It is currently is working and does not get hot. I may have dodged a bullet. I was hoping that the modified sine wave inverter was close enough to a sine wave that the net effect would be that would function normally. So far so good.There are fencers that run directly from batteries. Some are more efficient than others. I would find one
Fine if you run your inverter continuously. If you turn it off often to save battery charge, it won't serve your fencer. TheI don't want to get a battery operated since I have my whole solar panel - battery storage - inverter working and supplying power to my outbuilding. All the DC units I saw required a 12 or 6 volt battery. My unit is 24volt and so not convenient to use a subset of my batteries. I purchased the AC unit and plugged it in.
scheme I proposed will and very efficiently, desirable for off grid. Bruce RoeComment
