  • jfoust
    • Jun 2010
    • 4
    Total solar noob... Needs solar shed help!
    Hi everyone! I'm putting the finishing touches on my 10x11 metal shed, and was looking at buying some solar shed lights. The reviews on the pre-made kits are terrible! Everyone says the light is very weak, the build quality is poor, etc. I don't need anything heavy duty - I have a workshop in the house that I actually do work in, so the shed is strictly for storage. As such, I just need a light to see what I'm doing for maybe 10-15 minutes at a time. I'm thinking about building my own system - something that would last for a few years and actually put out enough light to dig around in the shed. I'm new to all of this, but if I understand correctly, I would need a panel, a charge controller, a battery, and the lights, correct?
    I was looking at the Morningstar Sunsaver 6 for the controller, and I have some 12v 12ah SLA batteries that I can use for power. (side note - would a lawn and garden battery work for this? I just need short amounts of power). I have no clue what kind of panel I should go with. I have a few options I'm kicking around for lights, but I'm definitely open to suggestions! If possible, I'd like to keep the panel/controller part around $100!
    Thanks in advance for the help!
    There are many LED replacement lights for Boats and RV's. They may not be as bright as a task light, but there are many choices.
    Battery - I'd suggest a marine deep cycle, about 80AH, common, inexpensive.
    Panel, depends on what's near you, but look for about a 50-100W panel. Still $$
    Charge controller, either Morningstar, Trace/Xantrex, or Blue Sky Avoid the un-namesd ones from china off ebay.
    Anything smaller than a 50W panel, will have troubel recharging a battery if you "grow" the system, and all systems grow over time. Gee, I could have a radio. Recharge cellphone. Laptop.......
    • jfoust
      • Jun 2010
      • 4
      Thanks for the reply! Do I really need 80Ah? I may want to run a small iPod dock or something similar for tunes while I'm working in the yard, but I doubt it... Having some room for growth wouldn't hurt, but this is really just going to be a place to get all the junk out of my garage, so I'd like to be able to see in there.
      I think I know which lights I want to use, and they're pretty low-draw LED spotlights, pre-wired for 12v. Assuming I don't expand the system, and it's just for shed lighting, what would a 15w panel do? I've run two of these same spotlights off a 12v 7Ah battery, and they last for hours and hours without needing to recharge, so I would think a low power panel would be fine, and even if it took a day to recharge, that's okay, because I wouldn't be dragging it down that fast.
        When you price out the 80AH marine deep cycle,
        DieHard Marine Deep Cycle/RV Battery, Group Size 24M
        $69.99 new - Sears
        and compare it to the
        TR22-12 Tempest AGM, Valve Regulated, Maintenance Free, Sealed Lead Acid Rechargeable Battery - 12V 22Ah (20 hour rate) $43 + shipping.
        Or you can just buy a 12V lantern battery, and run off that. forget the solar part, and save a bundle of $$
        But don't get the 15/45W harbr fright panel kit, waste of $
        A 15 W panel will just barely keep a large battery topped off, and days to recharge if you leave a light on overnight,
        • jfoust
          • Jun 2010
          • 4
          That's not too terrible on the battery. The storage shed is mostly for lawn and garden stuff, and also for Power Wheels parts and bodies (I have a huge collection of these things), so I have a lot of SLA batteries, and a couple of lawn and garden batteries as well.
          I could spare one of those batteries to run the lights, and like I said, with a 7ah battery, the spotlights last a long time, so I'm thinking that might work. It doesn't give me any expandability, but I guess I'd burn that bridge when I get to it!
            Well are you in that shed at night? Ever hear of solar tubes or sky lights?
            • jfoust
              • Jun 2010
              • 4
              Yeah, I'll be in it at night - that's about the only time I get to work on Power Wheels (we have over 20 right now) so I'll be rummaging for parts out there after the kids go to bed. I was hoping to not have to drag a flashlight, headlight, or otherwise out there every time, and it would be nice to get some illumination in the daytime as well.
              Plus the shed is a generic metal-walled deal. I don't know how if it could support the added weight of a skylight or anything else on the roof, and I don't know how that would effect the structure. Arrow doesn't sell any window, skylight, etc kits for it, so I'm guessing there's a reason for that.
                Daytimes, you will likely have better luck leaving the door open, small lighting won't make much of a dent from sun adjusted eyes. Nighttime, LED's and 12v CFL's should do fine.
