I'm a Nabcep installer and have installed Enphase, Solar Edge, Schneider, Solar Bridge and SMA.
Clipping is bad news. Wow not
If your clipping your not yielding all the power available. May be a big deal and may not
I also seen in here where you think that running an inverter "hard" makes it more efficient. That is exactly backwards. The best inverter efficiency happens at the 80% point of the inverters rating. Going above that pushes the inverter into less efficient operation and reduces it life.
At wide open your down over 2% from the inverter peak efficiency. Actual references for this if you would please - not personal opinion
Here where it gets cold a 250 watt panel will yield near 300 watts each. No enphase can handle that and it amounts to KWH's lost.
[ATTACH=CONFIG]6694[/ATTACH]
You will never ever see a Enphase do this and the heat matters. The hotter the inverter the lower the power out.
I'll install a Solar Bridge before an Enphase. Micro inverters are the last choice and the least efficient over any central inverter system. Again, references if making this statement
The Solar Edge arrays we installed has beat every other system out there for yearly yields. Including SMA and Fronius systems.
The micro inverter systems are always lower in yield. There easy to install and easier to expand but there the worst performing due to the 96% efficiency. Most modern central inverters are up around 98% efficient.
A 2% shift in efficiency on a 10kw array is 300KWh a year difference. If you live where it's cold then you need to allow head room in the inverter so you don't clip. Just look at the photo. Those are all 250 panels with some right at 300 watts. On a Enphase you'll never know what is really there. 300 kWh per x 15 cents = about 45$ per year? Who cares?
No matter what you decide power clipping is Bad. You spent the money don't you want every drop of power ?
If someone is telling you that a Solar Edge is cheaper than an Enphase some one is feeding you hay. Solar Edge is the most expensive system to install and for good reason. Nothing else comes close.
And with the modular Maximizers it's just as easy to add to a Solar Edge as to an Enphase and online monitoring is built into every Solar Edge. No extra 400 dollar box is needed.
Enphase die. Never mind it's under warranty. Had a car like that. Broke all the time but it was under warranty. Well it didn't cost me but I got tired of it being in the shop all the time and driving a loaner. Give them time and you'll be on the roof pulling panels.
It's time to get the snake oils out of solar.
