Both the revenue grade meter and the inverter display give total kWh as integers with no decimals. The revenue grade meter was changed out to an electronic one during year 1 so what I've done is take readings on both meter and inverter at the same time then I will wait for a couple of days to repeat then subtract to get the delta kWh for each. Over two days or so, the delta should be 85 to 90 kWh so should get an idea of how close the readings are. Now what did I do with the sticky note that I wrote the first set of reading on?!!!
re: dropouts, haven't noticed any lately.
Please help me decide on which way to go. (enPhase vs SolarEdge vs LG)
Regards.Leave a comment:
Just for kicks, I'm going to see how my Sunpower 7000 kwH display compares with the revenue grade meter for my solar production on the other side of the wall.I suspect it will take a couple of days of observation.Leave a comment:
Yes, SE data is inflated; their energy counters, in particular. See this post earlier in the thread for an example, but there is substantially more data that supports the conclusion. It still complies with the 5% standard they need to meet, and even though more accurate data is already available in the inverter if you know how to get it, they choose to publish the higher number.
Solar mfg./suppliers have nothing to lose by knowingly over reporting output to the extent of an over tolerance or more to the extent they can get away with it, just like vendors have nothing to lose and a lot to gain by underestimating array performance.
Users in states/areas or situations where utility grade meters are required - for SREC requirements for example, probably have a better handle on accurate output.
If output accuracy tol. is +/- 5 %, I'd put my money on closer to the -5% than +5 % every time and hope to be proven wrong when confronted with verifiable #'s.
I've not got a revenue grade meter (yet), but an educated guess puts my Sunpower reporting about 2-4 % higher than actual output. The array output is also about ~~ 2.8 - 3.0% higher than I'd otherwise calc., at this time probably due to panel over tolerance, which seems common for many reputable panel names.
Bottom line: monitor #'s coming from mfg./vendor monitoring equipment is from/by someone with skin in the game and therefore a stake in putting up as large an output # as possible.
Higher #'s look nice and feel good. I try to remember that not everyone who tells me what I want to hear is telling me the truth.
Follow the money.Leave a comment:
I guess the TED meter is either less accurate or the SE data might be inflated.Leave a comment:
Measuring inverter output on one leg is probably fine. I am monitoring both legs on mine, and the difference is insignificant.Leave a comment:
I bought a TED5000 and set it up a few days ago.
The TED5000 reports via pvoutput.org that for today (5/12) I produced 57.47kwh
The Solaredge monitoring website says I produced 58.54kwh
(1.8% higher reported by SE)
The TED5k only is measuring 1 leg (120V, not 240V), so there could be some error introduced there.
And I see yesterday 56.644kwh vs. 58.696kwh (3.6% difference) so it's not a constant % difference.
Yesterday and today had some clouds so some error could be due to sampling rate/size.
And it's quite possible that my TED is off - they claim +/-2% and SE claims +/- 5%.
But it seems likely that SE is calibrated to report slightly higher.
Also based on what they measure (volt & amps) the kWh calculating equation for SE may have less decimal places which tends to round up the numbers more then what the TED software uses.Leave a comment:
You'll note that in this thread there is question of whether SE is inflating their reported numbers - that people are still speculating about it as they don't have real proof.
I was just adding an additional anecdote.
I even asked on this website if anyone had suggestions.
Of course a week after I bought it, I see TED5000s with 3 inputs for $150 that could probably be upgraded to 4 for an extra $80.Leave a comment:
If you're going to bother to reply, at least read the entire post.
As I already said, TED says +/-2% for TED5000.
SE says +/-5%.
Of course neither are revenue grade.
Although I think SE has that option available if you want to pay for it. If you'd like to buy me a new inverter with the revenue grade feature, I'll be happy to hook it up.
There are many meters available for residential use that are revenue grade - cheaper than TED for sure.Leave a comment:
The revenue grade add on for Solaredge can be installed at any time. .. It is just a wattnode revenue grade meter with Ct's, costs maybe $400. The rs-485 protocol to talk to it is built into the Solaredge firmware, so the wattnode numbers become available through the Solaredge portal. For a few reasons, i preferred the ekm meter that i just installed, but could pass along the SE whitepaper on integrating wattnode to anyone interested.Leave a comment:
SE says +/-5%.
Although I think SE has that option available if you want to pay for it. If you'd like to buy me a new inverter with the revenue grade feature, I'll be happy to hook it up.Leave a comment:
But it seems likely that SE is calibrated to report slightly higher.Leave a comment:
