Most Popular Topics
Electrical Panel & Solar - Center Fed and 100A?
Yup, 10/3: two phases for the 240 V and one neutral. Plus earth ground. I forgot they output 240 V.
I believe data for the envoy is sent by the microinverters and embedded in the 60 Hz signal. The envoy gets the data through it's own 120 V power cord.Comment
From Enphase: "The voltage types are either single-phase or three-phase. All Engage Cable connectors bear labels indicating the voltage designation. Single-phase (3G2.5) Engage Cable includes three conductors. Three-phase (5G2.5) Engage Cable includes five conductors. Because Enphase microinverters output onto one phase, the 5G2.5 Engage Cable balances the phases by rotating conductor use from one microinverter to the next as shown in the following diagram. "
3G2.5 cable (ET10-240) is for 240 V (residential) So, the 240 V microinverters are one phase after all. Three conductors: line, neutral and earth ground.Comment
It seems reasonable that the three phase 208Y/120 connection also has each inverter supplying power from line to line (at 208 instead of 240) with the neutral not playing any role in power transfer.From Enphase: "The voltage types are either single-phase or three-phase. All Engage Cable connectors bear labels indicating the voltage designation. Single-phase (3G2.5) Engage Cable includes three conductors. Three-phase (5G2.5) Engage Cable includes five conductors. Because Enphase microinverters output onto one phase, the 5G2.5 Engage Cable balances the phases by rotating conductor use from one microinverter to the next as shown in the following diagram. "
3G2.5 cable (ET10-240) is for 240 V (residential) So, the 240 V microinverters are one phase after all. Three conductors: line, neutral and earth ground.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
3G2.5 is the part number for European installations. Their electrical standard is hot, neutral, ground. In the US, you have two hot phases 180 deg apart. Look closely at the US datasheet, you'll see red, black, white, and green.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
That makes more sense and matches the photos I saw. But, on the SDG&E net metering application they only list 1 phase and 3 phase as options. Not sure what to make of that. I'm checking 1 phase to match the 240 V.Comment
Yes, residential electric is 240 V single phase. In the US, because the 240 v is delivered by two hot conductors each 120 V to ground, but 180 deg apart in phase, it is sometimes called split phase power. In Europe, there is really a single conductor that runs 220 V-240 V to ground.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
And in all cases the micro output is single phase involving two wires, only the trunk cable and the voltage programming differ.Yes, residential electric is 240 V single phase. In the US, because the 240 v is delivered by two hot conductors each 120 V to ground, but 180 deg apart in phase, it is sometimes called split phase power. In Europe, there is really a single conductor that runs 220 V-240 V to ground.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
