Hello everyone,
I bought 42 used (about 5 years old) SunPower SPR-225's. What's turning out to be an issue is the positive grounding that they require. I'd like to install a Solaredge 7.6kW or 10kW inverter along with
42 P400 optimizers but my installer says the transformerless design isn't compatible with these SPR-225 panels. In addition, I can't use Enphase, SMA, or ABB micro inverters because of high voltage concerns in extreme
cold weather (I need to allow for -50C record temperatures).
Our design lends itself to strings of 6 panels. For that reason, he's recommending three SB-3000-US-12 inverters. He did originally spec larger SMA inverter(s), but he tells me the small number of panels per string
may cause problems with the minimum DC start voltage. The arrays are as follows:
SW Garage - 12 panels
SW House Wall - 12 panels
SW Top of house - 6 panels
SE Front of house - 6 panels
E Top of house - 6 panels.
Total: 42 panels - 9.45kW
I do have some flexibility with the last three arrays of 6 - perhaps removing the E array, and splitting the 6 panels between the SE front and SW top.
I'm going to contact Solaredge in the morning, but if anyone has any ideas; I'd love to hear them. Is there a way to implement the Solaredge solution with these SPR-225's? If not, assuming we don't want to change the design, which inverter(s) would you use, and how would you string the arrays?
Thank you for your time. I appreciate it.
