Solaredge should cost a little less but that does not make it a down grade. SolarEdge isn't standard optimizer, with solarEdge you are putting 2/3 of the string inverter on each. Module and the most critical part ( DC to AC ) is central. SolarEdge optimizers will not work with a regular string inverter. In this configuration OP would be limiting each module to 250w with enphase but not limiting with solarEdge.
Most Popular Topics
Solar Panel Install Inquiry - SoCal
In this case, the Solaredge sytem will outperform the enphase system at a lower cost. Not sure I would consider that a downgrade. As far as equipment quality, I have not seen evidence that either company's current product is superior. I notice many of your posts seem to be derogatory toward solaredge. Pretty much sounds like the sales people that tried to sell me sunpower and enphase.24xLG300N+SE7600 [url]http://tiny.cc/n7ucvx[/url]Comment
Solaredge should cost a little less but that does not make it a down grade. SolarEdge isn't standard optimizer, with solarEdge you are putting 2/3 of the string inverter on each. Module and the most critical part ( DC to AC ) is central. SolarEdge optimizers will not work with a regular string inverter. In this configuration OP would be limiting each module to 250w with enphase but not limiting with solarEdge.Comment
In this case, the Solaredge sytem will outperform the enphase system at a lower cost. Not sure I would consider that a downgrade. As far as equipment quality, I have not seen evidence that either company's current product is superior. I notice many of your posts seem to be derogatory toward solaredge. Pretty much sounds like the sales people that tried to sell me sunpower and enphase.Comment
I thought SolarEdge optimizers work with any string inverters, sort of like what Tigo was capable of? Tigo is being integrated into Trina Solar panels and being pushed out via Vivint Solar. From my research, there are articles and such that points to the panels rated output is only during optimal weather condition and with the appropriate sunlight hitting directly at it. Typically, that's about 1-3% of the year you'll get that kind of weather? People tend to oversize their panels to try and retain their maximum output since there are many factors that will not give you the solar panels rated number. Also, the solar panels will degrade every year. So in reality, not sure if you'll benefit greatly with SolarEdge.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
SolarEdge optimizers do not work with any inverter they are not the same as tigo and you will have lost quite a bit of power by the time the 305w modules degrade down to 250w and paid more for the privelidge of losing all that power. Yes people do oversize modules slightly as you mentioned 1kw Isi a lot of oversizing though. Your logic evades common since but your money not mine.Comment
You do know that the rated 305kw will rarely ever produce at full rated capacity as the rating is based on laboratory conditions right? In theory it sounds good. You can put a 4.9kw or higher inverter from SMA, SolarEdge, Fronius or whatever company you choose and the likely scenario is that your panels are going to end up producing roughly about 3.9kw to about 4.2kw on good sunny days during its peak. This is prior to ever seeing any degradation, dirt, or shade.
it makes no since at all to pay more for one option that will perform more poorly than the other, particularly with everything else equal to better with the cheaper option.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Your do know of course that a 305w module WILL produce over 250w and pretty significantly over it. Look around at pvoutput and you can see significant clipping on south facing arrays with 305w modules and M250 inverters. South facing systems seem to have 5+ Hours of clipping, conservatively 1kwh a day.
19 LG300 panels, M250 (5.7kw system)
32.2kw as of now
*each panel produced: 1.694
peaked at 5kw for less than 1 hour
16 LG300 panels, SE6000 (4.8kw system)
25.41kw as of now
*each panel produced: 1.588
peaked at 4.2kw for less than 1 hour
These live and current results are what it is right now from 2 very similar systems. Their numbers are very close and hopefully, the Enphase is a M250 not a M215. So... as for the clipping, it will happen and it's very minimal impact as you will rarely see that kind of temperature settings where your panels stays cool and directly facing the sun. As the sun shines onto these panels, unless you plan to spend money to keep them cool for the next 5 hours, the clipping you mention makes little to limited impact. The 5-6 hours is a number that would be of 1 year total, not on a daily basis. And of course the marketing BS and all their paid researches will show you numbers and stories that isn't part of reality. Hmmm... shouldn't those SolarEdge produced more power per panel since there should be no clipping???At the end of the day, I'm sure both system are similar and it's a matter of preference since each has their own pros and cons.
You keep referencing lab tests and results instead of real live output and capabilities. Just use SolarEdge's website and Enphase's website and look at their public system that is available. I'll pick out similar if not identical panels and both of these are located in Carlsbad, CA. Here's what I see:
32.2kw as of now
25.41kw as of now
BTW, the 4.8 KW system you quoted sounded like mine which has a SW orientation. So power production starts and ends late. But if you check at the end of the day, my system should be pretty high up in the chart in terms of efficiency. And it will only get better as the sun moves towards summer solstice.16xLG300N1C+SE6000[url]http://tiny.cc/ojmxyx[/url]Comment
32.2kw as of now
25.41kw as of now
HEre is a great example of a 2.4kw system with 8x LG300W modules with M250 enphase :
The SolarEdge one you give as an example seems to have a westerly azimuth:
pairing an M250 with a 280W module would have limited clipping as you mention but with a 305w module is where you might be over spending on the module compared to inverter.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
The topic of clipping has been debated many times in the past. Many times, it comes down to installation specific. For example, according to PVWatt, my system peaks in June to July time frame. Today it had about 3.5 hours of output wattage above 4KW which is the max if I had installed M250, even though the total extra energy in KWh is not that significant yet. One thing is for sure, if you're comparing two identically (or similarly) oriented system of Enphase and SolarEdge, if clipping does occur with Enphase, the SolarEdge system will definitely out perform in efficiency.
BTW, the 4.8 KW system you quoted sounded like mine which has a SW orientation. So power production starts and ends late. But if you check at the end of the day, my system should be pretty high up in the chart in terms of efficiency. And it will only get better as the sun moves towards summer solstice.Yes, it's quite efficient and compares favorably with the Enphase one. From what the chart is showing for daily, it shows 12:45pm at above 4kw and ends at 3pm. A little over 2 hours? There's almost no possible way to have identical comparisons unless someone decides to fork over the money and do it... Of course, this will need to be done outside of a lab environment. Unfortunately, for me the installation on my roof is quite expensive. Flat roof along with limited space...
I am not quoting any lab tests and never did. I have mentioned multiple times to look at pvoutput which is live systems.
pairing an M250 with a 280W module would have limited clipping as you mention but with a 305w module is where you might be over spending on the module compared to inverter.Comment
dhuong & buellwinkle,
Could you please PM me your contacts? I'm in the Glendale area. Much appreciated!Comment
San diego solar
Hey guys... PM me contact info as well... i am looking for 4-5kw system for my house in San diego... appreciate your help.Comment
You a peddler phishing for leads ? If not, why not post a question or two and a description of things like your usage and what you want to accomplish so we can all get a look and share ?Comment
