Most Popular Topics
Solar to mineral accretion underwater!
Okey Dokey, Vinaka (thanks in Fijian) guys,
So unfortunately the 50w being out of stock, I have an option of a 140w panel, specs are:
Isc 8.25
Vsc 22.1
Ipmax 7.9
Vpmax 17.6
The 50w panel we have talked so much about has:
Isc 2.95
Ipmax 2.73
Now am I correct in thinking if I wire these two panels in parallel I only get the highest amps of around 2.7, the same as my smaller panel? if so should I be looking for a similar panel in Isc and Ip ratings?
ThanksComment
If you wire the panels in parallel you will get the sum of the two currents, about 11A.Okey Dokey, Vinaka (thanks in Fijian) guys,
Isc 8.25
Vsc 22.1
Ipmax 7.9
Vpmax 17.6
Isc 2.95
Ipmax 2.73
Thanks
You get the lower of the two currents when you wire them in series.
To get the most amps for your buck, you need to go with the lowest possible nominal panel voltage.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
No Sir if you were to wire the panels in series voltage adds, well not in your case because you short the panels out. In series the current is limited to the LOWEST VALUE, not the highest value as you stated. If you were to add the 140 watt panel in series is really doing nothing as the current is limited by the smaller 50 watt panel of 2.73 amps. Putting the 140 watt panel in series is the same tossing it into the sea to never be seen again.So unfortunately the 50w being out of stock, I have an option of a 140w panel, specs are:
Ipmax 7.9
Vpmax 17.6
Ipmax 2.73
Thanks
You are only interested in current and could care less about voltage in your application because you are shorting the panels out. Current adds in PARALLEL so if you add the 140 panel you go from 2.72 amps to 2.73 + 7.9 amps = 10.63 amps.
Motto of this story when you go panel shopping the only number you are concerned with is Ipmax aka current at maximum power. You want the largest number you can afford.MSEE, PEComment
Vinaka!
Ok so another one, do I need diodes on both positive wires coming out the panels in parallel?Comment
Righteo,
Connected up the other solar panel in parallel and it is working a dream! Bubbling away at the cathode,
I have some more questions though,
So now I have upped my amps going to the structure by adding another panel in parallel, now what is happening is that mineral accretion is happening quite rapidly around the anode, further away from the anode accretion is slower and slower,
Ideally adding another anode would be great as it would allow a better spread of electrons over the cathode, however is it possible to split the positive wire at the structure to another anode and not have too much performance loss? Or will that greatly affect the amps getting to both anodes?
Thanks,Comment
The amps will distribute in proportion to the resistance of each circuit. If you managed to get the circuit resistance exactly equal for both, each would get half of the amps you are seeing now. In low resistance circuits like this one, it is generally hard to balance because a little bit of difference can skew the balance by a lot.Righteo,
Thanks,
You could add a small resistor in series with the electrode to help with the balancing, if you want, since you have room to add some resistance before the available current from the panels will start dropping off.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
The full amperage would continue to go through the cathode, although the current will be distributed over a larger area if i understand what you are doing, so the average current density will be less. That means the areas that have the most accretion now should slow down somewhat, but areas closer to the new anode will go faster.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
Marina power outlet to seawater electrolysis acreation
Hi there, I am trying to put together a project to transplant reef corals. I read and followed all your posts to Solar Marine who has a similar project to mine.
I am reaching to you because I have not been able to figure what would be the best and right way to get 1.23 volts at the electrodes.
The project will be located within a marina which is surrounded by a rock wall and close to regular city power supply. I would say the anode and the cathode cables will have to be around 65 to 70 feet long, there is 110 and 220 volts power supply available all around the marina.
I figure the cable coming out of the marina's pedestal power outlet goes to a transformer, then a cable goes to an AC to DC converter, then to a voltage regulator and from there the two electrode cables go in the water.
I am not an electrician or a scientist as you can tell but I love sea life and I want to see that marina full of corals.
I would greatly appreciate your advise.
ThanksComment
Go to the forum section you want to start a new thread in:
http://www.solarpaneltalk.com/forumd...for-homeowners
Near the top (but below the ads) is
+ Post New Thread Page 1 of 164 1 2 3 11 51 101 ... Next LastLast
Threads 1 to 20 of 3268
Forum: Solar panel systems for homeowners
If you are a homeowner who is about to put a solar panel system on your home or you are a newbie to the solar market, get started here! A non-technical forum to help you understand the in's and out's of solar.
The POST NEW THREAD is in a colored bubble box - click it and you get to start a new thread.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
The only other way I can think of to make a standard 12 volt battery panel to work is to use a Buck DC to DC Converter which steps down the voltage and boost the current to make the panel behave like a Voltage Source. But none exist for this application and would be a custom build specifically for the purpose.
Step it up at the panel to reduce the current losses (30V). Then step it down to 2V at the load.
Specification:
Input voltage:4V-35V
Output voltage:1.23V-30V(Adjustable)
Output current:Rated current is 2A,maximum 3A(Additional heatsink is required)
Dimension:43*20*14mm(L*W*H)
Model Specification:
1. XTW6009 boost module
2. Module Properties:Non-isolated boost (BOOST)
3. Rectification:Non-Synchronous Rectification
4. Input Range:3V~32V
5. Output Range:5V~35V
6. Input Current:4A (max), no-load 18mA (5V input, 8V output, no-load is less than 18mA. Higher the voltage, the greater the load current.)
7. Conversion efficiency:<94% (greater the pressure, the lower the efficiency)
8. Switching frequency:400KHz
9. Output Ripple:50mV (the higher the voltage, the greater the current, the greater the ripple)
10. Load Regulation:±0.5%
11. Voltage Regulation:±0.5%
12. Dimensions:43mm*21mm*14mm (L*W*H)Comment
