SETUP
I have a home built 12v solar lighting system . Has 3 panels (300W) to a wellsee MPPT controller then distributed to various LED lights. The regulator output is going straight to the LED lighting circuits via consumer on/off switches
PROBLEM
When the solar panels are producing charge during daylight hours the MPPT controller constantly flashes the red charge light about 3 times a second. This on/off cycle seems to be conveyed to the load output as a voltage spike, that appears to match the charge led's on/off switching.
For some LEDs that have a current regulator circuit board and a low forward voltage of about 3.2V, there is no problem, but other high power LEDs that have a combined forward voltage of around 10-12V, this flickering effect is very noticeable, probably because the high/ low voltage spike intersects the F/V.
ACTIONS
Tried putting large smoothing capacitor across output. (no improvement) Used CC driver befor leds. (No improvement.) Running lights directly from battery- (All works fine, no flickering.) Must be the charge controller.
QUESTION
1- Is this a normal behaviour for MPPTs during the charge cycle, or is this because I have a faulty/ poor quality MPPT?
2- Is there any way I can provide a smooth non spiking voltage to my LEDs?
3- Do you have any recommendations to improve this setup?
Thank-you for your comments.
PROBLEM
ACTIONS
QUESTION
