We had our 10 panel PV system installed just about 2 months ago. Our Inverter is a Fronius 3 (I believe).
For the first month or so I recorded the numbers on the power company's bidirectional meter. We are producing more than we are consuming and that is a good thing. Today we received our first electric bill.
From the bill : Production (324) - Consumption (233) - residual of old meter (22) = roughly the 70 kwh credit we will carry forward.
Today the meter reads Production (360) and Consumption (275)
BUT - when I look at the inverter it says we have produced 597 kwh. That is a difference of 237 kwh !!
Before installing the system we received 4 quotes. 2 of the 4 people were concerned we would lose kwh if we used the existing wiring between the area of the inverter (the pool room) and the meter (perhaps as much as 100 feet) SO we had new wiring (and conduit) installed.
From the manufacturers spec sheet the inverter itself uses 8 watts/hr when operational and <1 otherwise.
I'd appreciate any ideas on why the numbers on the inverter don't match up with the meter. I'm not electrically inclined. Could there be a short ? Could the gauge of the wire used be insufficient ? Is either the inverter or meter broken ?
Thanks
Thanks
